Alfa Romeo C42
MrGapes
34
Re: Alfa Romeo C40 Speculation
wonder if Gary Anderson will still have some doubts about rear push rod haha. But yeah massive sidepod inlet, similar philosophy to AM, interesting notches in the floor, teams will definitely be looking at that.
Giando wrote:
15 Feb 2022, 13:38
Marc.W wrote:
15 Feb 2022, 13:36
Side pod intakes look enormous :shock:
Yes. And the intakes position are also less advanced compared to McL, Haas, AT and AM were it is more or less aligned with the front opening of the cockpit.
Also, roll bar air intakes are very small, reduced even compared to 2021... quite bizarre.
It definitely looks like they removed stuff from the centerline and packed in the sidepods.
There were rumours of Ferrari doing the same.
jagunx51
185
JPBD1990
JPBD1990
51
I wonder if the sidepod inlets are actually smaller but painted black, similar to Aston. They look huge, and I can’t think of a reason why that would be the case vs the rest?
Saykas
Saykas
26
SiLo
139
Most interesting front wing so far. Looks like the central section is actually 4 planes and the rest of the wing is 3? Or is it just the angle?
Looking at the endplates it looks like 4 but hard to tell.
Felipe Baby!
Little Ducky
Little Ducky
Interesting to see the frontwing indeed. the top flap at the center is larger than the rest of the top flap!
Also the vortex generator is larger than other teams so far.
Roman
Roman
Yes looks like a Mini plane just below the nose. Also the nose looks to be a bit "inward shaped" something I have not seen yet on other cars.
General philosophy seems similar to AM with the big undercut.
Giando
93
JPBD1990 wrote:
15 Feb 2022, 13:55
It is absolutely possibile. Nevertheless as we were pointing out in previous posts, the roll-bar air intakes are very small, so they could have moved some cooling devices from above the PU into the sidepods. we'll see
wowgr8
wowgr8
29
JPBD1990 wrote:
15 Feb 2022, 13:55
I don't think they invest in slimming the sides and miniaturising the intakes the way other teams do, for whatever reason
MrGapes
34
Are those cooling gills below the Alfa Romeo logo?
*thick gurney aswell
F1NAC
172
jjn9128 wrote:
15 Feb 2022, 13:30
f1rules wrote:
15 Feb 2022, 13:28
Rear and front push rod
They buy this from Ferrari? So points to Ferrari going the same way?!
Isn't that collaboration over?
MrGapes
34
jjn9128 wrote:
15 Feb 2022, 13:30
f1rules wrote:
15 Feb 2022, 13:28
Nope Alfa are doing most inhouse, own gearbox hence own rear suspension
Re: Alfa Romeo C42
Aaand there you go. :)
AeroDynamic
349
Re: Alfa Romeo C42
