I work on technology transfer for roads and I know perfectly that not until I make some sort of model I will understand it completely. Besides, I won't be able to explain it to others until that. Anyway, the basic function is clearer than six months ago. If I'm able to make a simplified model of the mode of operation, which I plan to do, I will post it.
There you go, more food for tought. I'm wondering why nobody has posted, besides you. Emphasis (bold font) is mine, as well as comments in parenthesis, in italics, mostly interrogation signs.
I was a bit worried about the "second law of thermodynamics" comments. I wonder what you can get from a Stirling Engine coupled to an hydristor: how could you possibly keep the "energy sump" at a lower temperature than air? That should be true unless you use the "deep pipe" concept that takes advantage of the difference in temperature between ocean shallow water and deep water, for example....
Anyway, who am I to criticize? There is a working prototype and that should convince a lot of people in the forum. If you wish to take a look at a real machine working with an hydristor attached, I give some publicity to a video on Mr. Kasmer site (you probably have seen it, checkered, I know, but maybe someone here would wish to check it):
http://www.hydristor.com/LasVegas_IFPE_show.wmv
Here you have the wonderful Tom Kasmer, innovator extraordinaire, on the "floor" of F1Technical:
Tom Kasmer wrote:I am striving to design, manufacture and market a retrofit kit consisting of two Hydristors packaged into the form fit factor of a typical OEM torque converter. The 4 kidney ports are shared on either side by the input Hydristor connected to the engine with the outside Hydristor connected to the driveshaft. The hydraulic accumulator tank connects via a shutoff valve (to retain pressure long term) and is switched into the hydraulic pressure line common to the suction ports which are internally connected. During braking, the suction ports become braking pressure and the front engine connected Hydristor is shifted to zero (circle) which 'disconnects' the engine from the hydraulic dynamics. The engine can be completely turned off when sufficient pressure is stored in the tank. The infinite variability of the rear Hydristor allows for matching the energy of braking at speed to the desired braking effort and the tank pressure; where the speed decreasing lowers the hydraulic transfer of energy per the desired braking effort and accounts for the growing tank pressure as the energy is stored.
Bottom line: the retrofitted vehicle will come smoothly and safely to a stop and 95+% of the previous kinetic vehicle energy at speed will have been saved in the tanks for re-use. The motor is now idling to touch up the tank pressure, or is completely off. The front Hydristor can spool the engine up to idle speed very easily by ellipticizing from a circle to create a motor torque to rev up the engine for restart and this woll be similar to 'popping a clutch from rolling momentum to start the engine, or using tank pressure stored for 6 months by a virtual zero leak shutoff valve to start the engine from cold. This will turn the electric starter into an antique piece as it will grow old with lack of use. Driving at highway speed and a fair amount of tank pressure with the engine off or idling will enable the burning of tires to rapidly pass another vehicle while the engine spools up or restarts. As far as acceleration, a Hydristor retrofit RWD or FWD car will get to 60 in about 3.5 seconds on good pavement while 4WD/AWD vehicles will get there under 3 seconds, gas or diesel and with the engine turned completely off. The use of gasoline or diesel fuel will be cut by half or more while the generation of existing vehicular CO2 will be quartered. If all the vehicles on the planet were retrofitted to the Hydristor, the 10 year dire prediction of Dr. James Hansen of NASA could be averted. Whatever I do here in upstate New York, USA will affect you in Colombia and vice-versa. (I want to add) just a couple of side comments. The engine mostly idling or turned off will typically last a half million miles. Maintenance schedules will stretch out and the noise level will reduce at highway speed. The Hydristor torque converter can be completely controlled by a pedal and brake pressure/position resistance sensor which converts pedal demand into a very low pressure like 1 psi which is then amplified by the Hydristor just like the beta gain of an electrical transistor to the range of 5,000 psi and I'm working on a 10kpsi design as well. That one will use no hydraulic reservoir. I wish I could say more here but I have to finish my patent write ups first. The latest innovations will beat the Carnot cycle by recovering heat loss and turning that into more stored pressure. (???) By retrofitting all the vehicles already out there, the need to scrap everything in favor of the ineffectual hybrids will be gone. Somebody who owns a 7,000 pound Ford Expedition doesn't want to scrap it (losing their investment) in favor of some minimally safe vehicle which contains high tech batteries or super capacitors which will be interesting in hard crashes. Those components will push huge currents into an accident-derived short circuit. (???) This kind of thing is being worked on because there is no vision. ‘They' don’t know what to do or how to fix these major and future critical issues. The Hydristor can fix it all in one fell swoop!
And, the Hydristor Super Freon Heat Pump/Stirling generator can harvest the solar heat from the air and water to make free, true zero emission electricity. (???) I will build my car as soon as I finish a negotiation with investors. My car of the future will 'just run', trashing the so-called second law of thermodynamics which says I can't make a machine which absorbs heat from the air and produces some of that energy while being self sustaining. (???) What did they know in the 1800s when some of these 'rules' were coined by the experts in physics? I am working toward the future world and I hope you all will join me. I see a future where everybody has free energy and the energy generation fits the natural environment of the creator.
I thank you for the interest and for motivating me anew. (Best) regards.
Tom Kasmer
