@ mep: yes, your explanation is the same thing I tried to say. You have a low oxygen mixture and you rev the engine using downshift. This is the reason why even "normal" engines with poor ignition some times detonate (produce a loud bang) when you downshift.
@ slick: I also believe that some engines control the rpms by cutting the spark, the same way the gadget I posted works, so this is possibly another reason. We need here an "specialist" to be sure.
@Birel99: well, I always think of an engine as a air pump. The fact that is mixed with gasoline affect little the performance of valves, intake and exhaust. The best engine is the one that pumps air more efficently.
Now, picture for a moment an engine on the first stroke: the cylinder is going down, the intake valve is open and the air-gas mix is entering.
If you close the intake valve just when the piston reaches the bottom of its movement (what is called "BDC" or "Bottom Dead Center"), you are going to stop the inrush of air right when is entering the cylinder at its highest speed.
The air has inertia, like almost anything in this world. So, you left the valve open a little more time, with the final effect that, even while the cylinder is moving up, on the compression stroke, the air is still entering the cylinder because of that inertia, giving you a little extra mixture inside the cylinder.
The opposite is true on the exhaust stroke: even when the piston has moved away from the TDC (top dead center) and it's starting to move down, (theoretically it has started the intake stroke), the air is exiting at top speed and it "pulls" a little extra air out.
Finally, when you overlap the exit and intake of air, the exiting air helps to "pull" in the intake air.
This effect of the "inertia of the air" is more noticeable at high rpms, simply because the air is moving faster. This is why the overlap of the valves is greater in race engines, that develop ultra-high rpms.
The "magic" of valve design and manufacturing resides in closing the damn thing right when the air stops moving across it, not when the cylinder is at an arbitrary "theoretical" position at TDC or BDC. This theoretical position is good only for extremely low rpm engines.
Incidently, this is the reason why it is so hard to keep a racing engine at low rpms (just hear a drag car when it is idle: the engine sound is extremely uneven) and it is so easy to stall a F1 car on the grid or on the pits.
This is also the reason why it is forbidden to have variable timing camshafts, like the hydraulic or electric systems devised for "normal" cars. Actually, I don't understand the reasoning behind it, but if you had variable camshafts, F-1 engines would develop even higher accelerations from a standing start: the engine valve overlapping would be optimum at any engine speed. This is the reason behind the "desmodromic valve" design of some motorcycles.
After writing all this (which for people that work on engines is basic stuff) I am not sure if this is a dumb question. It is important to understand all that if you want to appreciate a racing engine and the kind of compromises you have to make, as a good engineer, between theory and real life.
At least the next time your favorite driver stalls miserably the engine on pits exit, when the race is on the balance, you'll understand that it's not his fault: it is the design behind the engine what makes him miserable. Of course, the best drivers (like, I don't know, JPM or Alonso
) never ever stall the car, but that it's not easy.
Anyway, if you keep saying your questions are dumb, I will be surer that my limited answers in "engrish" can be useful...
I only hope that my long posts are clear. You tell me.
