Ferrari's Longer Wheelbase = Lack of Overtaking Ability ???
mep
29
Thanks for the help Carlos.
segedunum
segedunum
bizadfar wrote:If massa took your advice, he would've spun in the middle of the track. It's clear from the onboard he was losing rear grip under braking (hence the correction, and the running wide...)
Sorry, but that's utter crap. It was Massa's mistake, he was clean through and totally missed his braking and turn-in for the corner. He was losing rear grip under braking simply because he missed the corner, didn't turn in and braked far too late - hence the attempted correction and the running wide.
What you believe you saw from the on board shots is entirely up to you.
