The degree of strain (flex, if you like) will be dependent upon the stiffness modulus of the various parts and the stress (force applied). The issue under discussion here is the clearly controlled (and desireable) means of strain under stress. Fatigue is a complex and, for the purposes of this discussion, redundant issue which is not necessarily related to the amount of strain. Provided the strain does not exceed the linear (elastic) range of the material fatigue should not be an issue - at least over the duration of a race.They are going to have some flex, no matter how well they build it. It has to, premature fatigue failure would take hold if nothing had any give. A Skyscraper flexes in the wind to prevent structural failure and it's made out of concrete and steel.
lol that wasn't memistareno wrote:modbaraban - As I said earlier. Use photoshop (or similar) to overlay an image from on the main straight with a low speed image (using the lap graphic as a film reference point) This removes the illusion of extroneuos movement created by the suspension movement and you will find that there is actually very minimal movement of the rear wing. Certainly no more than would be expected of any remotely mounted wing at high speed.
BTW - Just because you use words such as 'clearly' (3 times in a paragraph) doesn't make it so. I'd be very suprised if there is any action ever taken about the wing and what is *clearly* a normal amount of flex on a stressed component.
modbaraban wrote:lol that wasn't memistareno wrote:modbaraban - As I said earlier. Use photoshop (or similar) to overlay an image from on the main straight with a low speed image (using the lap graphic as a film reference point) This removes the illusion of extroneuos movement created by the suspension movement and you will find that there is actually very minimal movement of the rear wing. Certainly no more than would be expected of any remotely mounted wing at high speed.
BTW - Just because you use words such as 'clearly' (3 times in a paragraph) doesn't make it so. I'd be very suprised if there is any action ever taken about the wing and what is *clearly* a normal amount of flex on a stressed component.I re-read my BOTH posts and failed to find this word (clearly) at all
U dont have to do all that work.. it is obvious man... the wing is barely flexing... im not saying it is not, but the flexing amount is similar to any other car i guess... does anyone have any similar onboard videos guys?mistareno wrote: Mikey_s - As I said earlier. Use photoshop (or similar) to overlay an image from on the main straight with a low speed image (using the lap graphic as a film reference point) This removes the illusion of extroneuos movement created by the suspension movement and you will find that there is actually very minimal movement of the rear wing. Certainly no more than would be expected of any remotely mounted wing at high speed.
