http://scarbsf1.com/JAG/JAG_third.html
The 3rd damper/spring/packer is connected to a ball-and-socket like joint in one side and a "T" on the other side. This "T" is conected on the other side to the "commonly used" 2 spring/damper/packers. The 3rd damper works when the 2 wheels are loaded equaly ( like in aero load). With this you can use a "softer commonly used 2 spring" setup in order to have more mechanical grip and you have the 3rd to maintain ride height when high aero loads are applied.
Without this you would have to use stiffer/harder suspension to prevent the car touching the asphalt at high speed.
In other terms, its a passive suspension configuration that "works a little" like an active suspension with no 3rd spring.
NOTE: this was a very very raw explanation, excuse that! Now I dont wanna see 3000 posts commenting how many mistakes I have made. Unless it is adding something
