Birel186 wrote:I think they have the exhaust coming from the top so the heat helps with downforce on the rear wing.
Exactly, the exhaust gas velocity works to entrain the flow through the 'tunnel' between the bottom of the rear wing and the top of the mid wing. This will increase the velocity through this area of the car and should help pull air out from under the car, effectively making the diffuser generate more downforce. In essence, it works the same way as putting the exhaust on the bottom of the car, but I think the main difference is that it does not make the diffuser as sensitive to engine RPM and thus you maintain better stability because the aerodynamic center of pressure is not fluctuating as wildly front to rear.
I love to love Senna.
