1.Shock absorber and spring
2.Upper Wishbone . The front upper wishbone is attached on the engine
3.Pushrod
4.Lower Wishbone . The front lower wishbone element is aatached on the gearbox
5.Aerodynamic cover of differential
6. Mechanical engine starter
1. Small barge board in front of the main one connected to the protruding horizontal turning vane
2.Guide vanes
3. Three elements are kept together by two horizontal edges that split the airflow into three portions, all directed outwards to reduce the turbulence generated by the front wheels and to increase the airflow, and hence downforce, underneath the car
