RacingManiac wrote:Well spec tires means that the car and the drivers at the end of the day have to make the difference, not the tires.
I see what you mean but i think we need to nuance it. In every driver's difficulty to heat the tyres there's the mechanical/aero set up of the car influencing.
I reckon some driver's style just fit more than others to that, but should we say then the one that can heat up their tyres are better?
I mean wouldn't the driving challenge be based on each one style and see who's the best one.
I say that while knowing that a good driver is someone who can adapt but this time i think it nullifies a bit each drivers specificity, so i don't really agree this let the driver in commands.
But for sure many races in tire war's day were even not at this level, there was simply too much difference in performance.
RacingManiac wrote:
If we want to compare engineering, you always keep as many things the same as you can, and the things you are changing will be the deciding factor.
I disagree. If you keep thing even and see who is adapting better, you are in a set up challenge which is not different from spec series.
Engineering challenge is based on who brings the best answer to specific problem hence that means differents solutions.
I think in F1 the current real engineering challenge is KERS.
Aerodynamics are second but shrink more and more.
RacingManiac wrote:
And having control tires in a WDC/WCC setting does not influence the fact that you are looking for a best driver and best constructor.
For sure but that blanks the car construction's differences. You have one type of tyre so you need to build your car for them.
This was not the case before and seemed logical.
It is like if your imposed standard brakes or engines, you would need to built the car for maximizing performance according their architecture and thus it would make the thing even.
A very good example are aerodynamics. Restrictions in dimensions, uniques tyres and freeze of the engines just made the aerodynamics solutions very similar between teams.
RacingManiac wrote:
If you are putting tire into the mix and each team basically have to work with a constuctor to develop a tire for them, it really adds to the logistic of things since not only now they are developing parts for the car, they have to be constantly testing to develop the tires. Look at 2005 when you have a crappy BS and good Michelin. There are weekends where all the Michelin team would do well because their tires, and team like Ferrari on their inferior BS will get beaten by the likes of Toyota. Does that really reflect the status quo of the real "constructor" championship, in that Toyota makes better F1 cars than Ferrari, or its just so happen that they are on the better tires?
Yeah i agree, but as i said above, the benefit of having tyre war is that you can ask for tyre redefinition (at least in the form of tyre war that existed in F1).
That adds costs for sure and yes that can have so much influence on performance that tyres can make a worst car being faster but that's part of the formula.
As you said, michelin equiped cars were not all equiped with the same michelin. Many teams had their own tyre specificities so that is part of the constructor equation to me.
