bcsolutions,
The problem with a "w" engine configuration is that it has 3 cylinder heads, by nature. The packaging of the intake and exhaust plumbing would be problematic, at best.
There is no limit for wheelbase on F1 cars, so engine length is not a major concern for chassis designers. All F1 engines must have 10 cylinders per current rules. And of course, a "W10" would be shorter and more torsionally rigid than a "V10", but the question begs, "How do you divide 10 cylinders into 3 cylinder banks?".
Of course, all of this discussion is academic. For 2006, all F1 engines must be 2.4 litre 90 degree V8's. Cosworth already has their's on the dyno, and it's revving to over 20,000 rpm. So much for the FIA's cost cutting rule changes!
http://www.grandprix.com/ns/ns14635.html
Regards,
Terry
