Aerodynamicist#1 wrote:Msc Aero? Haha i think i'm maybe just a wee bit more qualified.
Really? Your profile says you're a 4th year student. So either, you are VERY slow at getting your advanced degree (...), or you have no degree at all. Also, asking questions this basic makes me think you aren't qualified at all:
viewtopic.php?f=6&t=6011&p=84700#p84700 You do realize your posting history and profile are viewable by all? Might want to make posts with the coherance of a bachelor's degree holder
before claiming you've got degrees beyond an MSc. BTW, how's your multi gridding report going?
Ever heard of stratford pressure recovery? you need to have a laminar flow to be maintained for as long as possible in order for a descent pressure recovery and maximum downforce, because the alpha effective change is not large enough to cause the maassive stall associated with large alpha effective angles when stratford recovery is used for say an aircraft wing.
I suggest you return the books to the library and go get a job.
All F1 car rear wing aerofoils are designed with Stratford pressure recovery. The more laminar flow, the greater the pressure differential. The flow is sometimes tripped by some mechanism about 3/4 chord to initiate the recovery but you want to maintain laminar flow up to this point, however for the fella who asked the question, he isn't going to have the resources to work that one out, not even with CFD unless he has allot of time!
Any gains from these small increases in pressure differential provided by the laminar flow are erased by the HUGE decreases in pressure differential when the wing STALLS EARLIER. RACECARS ARE NOT AIRCRAFT.
You are applying ways of decreasing drag on aircraft in cruise conditions to race cars. Guess what? F1 rear wing CL = 4. Aircraft cruise CL's are ten times smaller or more. Laminar flow on a nose that separates WILL re-attach, so the advice to keep it smooth at the expense of enormous cost and manufacturing difficulty is pointless. You're worrying about laminar flow for tiny amounts of pressure recovery on a rear wing which also has MASSIVE total pressure losses due to the wake of the car and driver in front of it? At a Formula student level, he is MUCH better off just getting it all turbulent and having it stall later than gaining 0.00000001% from keeping the nose laminar instead of accepting small separation and re-attachment.
I suppose you also believe us CFD users are wasting our time because we haven't heard the theories of 12th order accurate DNS schemes
I think he's gonna want to avoid bumps ripples, parasites etc on his bodywork as best he can
Pure bullshit. Can you defend that and substantiate how a ripple on the nose will ever make a significant difference?
I'm sorry but you couldn't even name an aero text - go read Anderson's Fundamentals of Aerodynamics. By the way
It just does.
what a poor arguement, i'm sure that one gets you far! Haha
I guess you skipped the part of Anderson's book where he explains that a turbulent boundary layer stays attached longer. Or the decades of Boeing and Airbus conclusions. Or every book/paper on high lift aero ever written. Or the complete EXISTENCE of vortex generators, who's sole purpose is to keep flow attached longer than it would were it left laminar. Looks like YOU need to be doing some reading, kid.
What are you, a 19 year old student?
