Ferrari F60 aero-mech development in 2009
FLC
FLC
Re: Ferrari F60 aero-mech development in 2009
bar555 wrote:The only visual change for the vertical turning vane is the red colour , which is now extended lower . The panel starts with a vertical profile and towards its bottom rotates to a horizontal profile to divert airflow around the very sculpted sidepod.
The turning vanes did change from launch to Australia. It's very hard to see but Ferrari added a small dent to the element that connects to the sidepod:
I only mention this because in China they've updated that area again (and i'll leave that for bar555 to keep on his great work), and I think it should be interesting to see how that area keeps evolving on a car that's had almost no changes at all.
Also worth mentioning is that the upper connection element has changed accordingly (easy to notice thanks to the screw...):
On the left is before the change.
bar555
bar555
Thanks a lot for the notice ,
Sometimes it is really hard to observe and follow all tiny evolutions , especially when i have to cope with all teams
Future is like walking into past......
Blog : http://formula1techandart.wordpress.com/
Twitter :http://twitter.com/bar555onF1
bar555
bar555
ENGINE COVER - AUSTRALIA
Ferrari had also a new engine cover . The “hump” on top of the cover was replaced by a more convenient design .
AIRBOX WINGLETS-CAMERA - AUSTRALIA
Apart from the T shaped camera there was a winglet attached on the left side of the airbox . For Massa only a camera was fitted inside the winglet .
Ferrari also used only during free practice sessions , a small camera attached on the right side of the airbox .
REAR LIGHT - AUSTRALIA
FRONT BRAKES - AUSTRALIA
1.Disc holes
2.Brake duct
3.Small winglet with a small endplate
4.Larger winglet added to the upright of the front wheels . It could be considered an unsprung aerodynamic device
5.Callipers
FRONT WHEEL RIM SHEILDS - AUSTRALIA
The static wheel rim shield improves brake cooling and better hot air extraction and a better hot brake coming air flow towards the rear of the car . The winglet above the wheel nut further improves the airflow towards the rear .
REAR WHEEL RIM SHEILDS - AUSTRALIA
bar555
bar555
ENGINE
Engine : Type 056
Number of cylinders: 8
Architecture: Cylinder block in cast aluminium V 90°
Number of valves: 32, Pneumatic distribution
Total displacement: 2398 cc
Piston bore: 98 mm
Weight: > 95 kg
Injection: Magneti Marelli digital electronic injection
Ignition: Magneti Marelli static electronic ignition
Fuel: Shell V-Power ULG-66L/2
Lubricant: Shell
COOLING REAR VENT - AUSTRALIA
The cooling vent’s overall outlet size was reduced a lot since Launch , to decrease turbulence and drag .
DIFFUSER - AUSTRALIA
DIFFUSER - BAHRAIN FEBRUARY TESTING
alelanza
alelanza
On the sidepods there's a tiny squarish hole right beneath the main aperture, i guess it's to cool something, does anyone know what gets cooled by it? gearbox/diff? kers? electronics?
Thanks!
Alejandro L.
bar555
bar555
alelanza wrote:On the sidepods there's a tiny squarish hole right beneath the main aperture, i guess it's to cool something, does anyone know what gets cooled by it? gearbox/diff? kers? electronics?
Thanks!
Could you post an image of that hole ?
Gonner
Gonner
I think he's talking about those holes :
alelanza
alelanza
Gonner wrote:I think he's talking about those holes :
Exactly! :D
We were wondering about this pic here:
I have no idea if what's stuck in there is part of a cooling device or a breather or what :)
Alejandro L.
I think the right one(on the pic left) is for kers cooling, on the other side is probably the ecu wich also requires some cooling.
The F60 seems a car with a as low as possible CG so these parts cant take their cooling air from the regular hole anymore
timbo
timbo
113
Note that R29 had similar holes on winter testing, later they extended radiator intakes.
Both cars (F60 and R29) run Magnetti-Marelli KERS system
Shahbi
Shahbi
nyc...awsome work dude.. =D> !
u r fanatic..!
got full details..!
can u plx giv details of steering wheel buttonz n optionx..!
n whox Nigel Stempney..?? :roll:
bar555
bar555
Shahbi wrote:nyc...awsome work dude.. =D> !
u r fanatic..!
got full details..!
Nigel Stepney , a former Ferrari mechanic ,
why former ? read the following
http://en.wikipedia.org/wiki/Nigel_Stepney
http://www.autosport.com/news/report.php/id/60448
http://www.formula1news.net/nigel-stepn ... -sabotage/
http://blogf1.co.uk/2008/10/24/white-po ... were-true/
As regards the steering wheel i will explain what the buttons are for but you have to wait . If you can’t wait though you can check this viewtopic.php?f=6&t=5332&start=135
for the 2008 Ferrari steering wheel until the 2009 version shows up .
Astro1
Astro1
F60B on track
http://www.youtube.com/watch?v=pXWWP_ggTc8
one more
http://www.youtube.com/watch?v=k6DkY3kijCI
Enjoy!
It's difficult to see, but it looks like the new diffuser is on, and not only that, but Ferrari may have adapted or at least gone closer to RBRs design of extending the wing endplates all the way down or at least part way down and connecting them to the diffuser. Maybe not the lower channel, but the upper.
The sidepods also look smaller, and the exhaust is now more like the one on the debut car but still different. It also looks like the car itself sits lower at the front with the front suspension angle changed (possibly the shape of the nose) and the body work engine cover around the rear suspension looks more covering. Also the heat shielding around the exhaust is different and seems to extend towards the rear suspension and form some sort of bodywork.
It's difficult to see anything else from the poor video (It helps to press the HQ button for better quality).
alelanza
alelanza
wesley123 wrote:I think the right one(on the pic left) is for kers cooling, on the other side is probably the ecu wich also requires some cooling.
timbo wrote:Note that R29 had similar holes on winter testing, later they extended radiator intakes.
Thanks guys!
Alejandro L.
Astro1
Astro1
Looks totally different, though not quite what I was expecting with the diffuser. It could be an intrim version though.
It appears that the car is more sculpted at the rear, new exhaust, new engine cover, new sidepods. New rear wing (4 slots), diffuser new, but not DD. There does appear to be some interesting bodywork around it and the center has been opened up.
