Jersey Tom wrote:I can't think of an example where moving the CG forward would result in anything other than increased understeer.
I suspect the issues being discussed have been sorted now, but here is my contribution.
This thread is about changing wheelbase of a be-slicked aero car, rather than (simply) the position of the centre of gravity. Hence, while a simple change in c.g. position (with all else held constant) will have the effect described by JT & Sundevil, the reality is more complex, as autogyro suggested.
Suppose Merc. has a driver complaining of understeer & measurements to show that the front tyre temperatures are lower than ideal. If the wheel axles are moved aft relative to the c.g. (hence moving the c.g. forward), then the front tyres will be "worked" harder, and can therefore be expected to stabilize at a higher working temperature. This will increase front tyre "grip" (up to a point) which is likely to over-power all (or most) other considerations & lead to a nett balance change towards oversteer.
A c.g. shift will, of course, be matched by a centre of pressure shift for an aero vehicle when the wheel axles are moved, which helps my argument, but the argument is still valid for a non-aero vehicle using slicks. Working the tyres correctly is the single most important objective when setting up the suspension of a non-aero vehicle, & it is also important for an aero vehicle. Set-up options in the latter case might be compromised by aero constraints, which explains the importance of being able to adjust c.g. position, & also why a change in tyre specs. can require the c.g. position to be moved.
