The front side impact crash structure remains uncovered for the F10 , just like the F60 , but two triangular fins were added on each side of the cockpit , just in front of the crash structure .
FRONT WHEELS
Apart from the wheel fairing absence , it is interesting to observe that the wheel nut has been increased now in size .
SIDEPOD PANELS
They look very similar to the ones used by the F60 during the last 2009 races . The only striking difference between the two configurations is the number of the mounting elements , reduced to one in F10 from two in F60 .
EXHAUSTS
Not only the exhausts pipes are blowing closer to the centre of the car to permit a more slim rear end but the whole exhaust system seems to be refined in order to offer a more compact body design and a cleaner airflow towards the rear wing .
To make such a configuration possible the mechanics placed the exhaust pipes inclined backwards and closer to the centre of the car . I assume this may intense the heating problems and maybe that’s why the F10 features large hot air exiting cuts at the rear. This idea is not new as it was already used in F2005 and Sauber C24 in 2005 .
HOT AIR EXITS
The F60 features a small cut where the engine cover meats the rear suspension covering , a similar approach was chosen for the F60 during the first races of the 2009 season . The F60 cooling needs depended greatly by the track conditions and through the 2009 season many different types of cuts for aiding cooling were presented . The F10 even features large hot air exits at the rear , like F60 ( pre and after Spain opening type ) but now they seem to be a bit larger .
REAR LIGHT
DIFFUSER
The F10 ‘s diffuser has a completely new central part , resembling to a Triple Deck one , with three large main centre openings .It is though amazing how large is the third upper opening . Apart from this , the side parts are not altered dramatically , featuring a single vertical element . The new nose cone was possibly designed to feed better the new TDD .
