sevor of moveable front wing
Re: Front Wing Adjuster...
raymondu999 wrote:What I don't understand is, what do they do with it? When following in the wake of another car, do they give it a more aggressive angle by 6 degrees to counter the understeer? Or do they decrease it and just make it lift neutral so it's not buffeted by the wake?
it is used as a balance trim by most if I am correct.the possibility to compensate for lost front downforce in the wake was the original idea of the adjustment but 6 °
seems to be not enough range...
autogyro
autogyro
I cannot see how any wing angle adjustment can compensate for turbulent air.
raymondu999
Hey all. A new thought just popped into my head. Drivers are allowed 2 wing angle changes during a lap, 1 to a new setting, and the 2nd one must be to go back to the old setting, by 6 degrees. 1st, is 6 degrees the *mandated* change, or is it the *maximum* change (meaning they can change 1, 2, 3, 4, 5, 6 degrees)?
Next, do they *have* to switch back to the old setting? Everything I know seems to point to *can* change it back. So for example, could it be possible, say, for a driver to increase it by 6 degrees this lap, then not change back, then increase it by another 6 degrees, and so on, in the next lap?
失败者找理由,成功者找方法
ESPImperium
ESPImperium
64
Personally id allow the FFA to be adjusted an unlimited ammount of times per lap, by up to 10 degreese at a time.
Its a amazing feat of engineering, one that is simply amazing on the modren F1 car, up there with any other technology on the modren F1 car.
