Hey guys,
I'm a little confused with the physics behind the rule: Reaerward weight bias = oversteer, and front weight bias=understeer.
The way I see it, the momentum of the car is the same regardless, and by shifting wiehgt forward the normal force on the front tyres is larger, causing more grip and hence oversteer.
When I heard I was wrong, I thought about it another way: The centripetal force required to keep the rear end in line is larger if the rear end has more mass, hence moving the balance rearwards will cause oversteer as is the rule. Problem is though, wouldn't this increase in centripetal force required by fullfilled by the extra reaer grip due to increased normal force?
Thanks guys
