Comparison of F1 and LMP1
machin
162
Re: Comparison of F1 and LMP1
Considering the difference in engine power outputs, isn't it more informative to compare BSFC rather than a MPG or l/km? Altho I concede, from the available data it would only be possible to calculate an average BSFC...
It would be interesting to compare the BSFC of an F1 engine to a small capacity Turbocharged LMP engine...
620 kilo f1 is with driver ,the 900kg lmp1 one is without.
Belatti
Belatti
F1
V8 90º Gasoline
32 valve, 2.4 Liter
Engine weight 95Kg
18000 rpm max
Power arround 750 HP (guess)
Torque arround 290 Nm (guess)
Fuel consumption 55 to 60 l/100 km (1.9 GJ/100 km)
Fuelling: 8 injectors supplied by a pressurized system at 100 bar
7 speed gearbox
Car Weight 620Kg -driver
Fuel tank 200 Lts +
Wheelbase arround 3200mm aprox
Width 1800mm
Tyres Front: 245/55-13
Tyres Rear: 325/45-13
Le Mans (Audi R15)
V10 90º Diesel twin-turbo
2 x 39.9 mm engine-air intake restrictor
2.94bar
40 valve, 5.5 Liter
Engine weight ???
Power 600 HP
Torque 1000 Nm
Fuel consumption (1.6 GJ/100 km)
5 speed electropneumatic gearbox
Car Weight 930Kg
Fuel tank 81 Lts
Wheelbase arround 2980mm
Width 2000mm
Tyres Front: 330/68-18
Tyres Rear: 370/71-18
Peugeot 908 HDi FAP
V12 100º Diesel twin-turbo
48 valve, 5.5 Liter
Engine weight ???
Power 600 HP
Torque 1000 Nm
6 speed electropneumatic gearbox
Car Weight 930Kg
Fuel tank 81 Lts
Wheelbase arround 2950mm
Width 2000mm
machin
162
Taking the earlier post of consumption rate at Brazil for an F1 car of 2.4 litres per lap and assuming a lap time of 75 seconds, results in an average consumption of 115 litres/hour, Assuming that the the engine is producing an average output of 80% of its peak power during this lap (That's a pure guess, so happy to take advice on this?), the average brake specific fuel consumption that results is 0.192 Litres/BHP.Hour.
Just looking on the Le Mans website, the Oak Racing Mazda (2 litre turbo), pitted on average every 50 minutes, assuming it still had 5 litres left of its 80 litre tank when it pitted, means a fuel consumption rate of 90 litres per hour. Assuming its average power output during this time was 90% (again, a pure guess) of its peak power of 500BHP results in an average brake specific fuel consumption of 0.200 litres/BHP.Hour
So on that very, very quick and dirty sum the F1 engines look to be slightly more efficient... but of course there's way too many variables to really draw a conclusion.... fuel lower calorific value, etc, etc... to be completely sure
machin
162
Same numbers for the AMR Eastern Europe Lola-Aston (large, NA petrol engine)... Pit stop every 50-ish minutes, 90 litre tank, assuming 5 litres remaining at pit stop, results in a fuel consumption of 102 litres/hour. Peak power is 650bhp, so taking 90%, the average brake specific fuel consumption is 0.17 litres/BHP.Hour.... so better than the F1 car in this case....
DaveW
DaveW
239
WhiteBlue wrote:So LMP1 would be 11.3% slower than F1. That would be significantly outside the 107% rule of F1.
Anyone care to guess what the cost in lap time would be for an F1 vehicle with
a) 380 kg of fuel on board &
b) 150 HP less.
b) 150 HP less.
:mrgreen: :mrgreen:
