Yes now we are getting somewhere, would you care to post pics. What i really wanted to see is more numbers as it relates to finding the exhaust velocity.Jon wrote:Guess what mate? You can do it yourself!!!Just_a_fan wrote:Mods!
Any chance you could auto-remove autogyro's continued and inappropriate injection of his "wonder-box" in to every other thread on this forum?
It's getting extremely tiresome seeing it crop up again and again and again and again and....
Just a fan, meet the "foe" list. "Foe" list, meet Just a fan.
Back on topic...
Well, I believe McLaren abandoned the blown diffuser with the MP4/16 of 2001. The 2000 car still had it, and that engine reved between 17,000 and 18,000 rpms. So, about the same as they are now...and yet they dropped the concept...ringo wrote:It could be a possibility, but i think we need to look at the cars themselves and find out why it is an exhaust blown diffuser is a net gain on a 2010 car, than say a car from the early 90s or late eighties.
What i find stands out is the engine speeds. Cars today rev at 18000~20,000 depending on which year and engines you are looking at.
Hmmm...what does that mean?
Not being the most modest man on the face of the earth myself, I honestly don't think that you are either Auto?autogyro wrote:Just explaining how an exhaust driven diffusser could logicaly work, I though the aero nerds would approve.
I had no idea that Ferraris inability to make one work would cause such a problem.
I like that thought. RBR's pull rod layout moves weight (& volume) forward & down (all good but, perhaps, comparatively insignificant). It ensures that the rod is clear of the exhaust flow (probably more for thermal than aero reasons). It would also, presumably, provide more flexibility to position & direct the exhaust flow to make best use of the energy. Closeups of the rear of the vehicle would be useful to suggest what (if anything) might interact with the flow & whether some of it might be diverted (a diffuser energizer, perhaps).marcush. wrote:placing the exhaust exit upstream and have a zone where it can mix with the car flow....
quite an intriguing thought .ringo wrote:I think that is probably the same reason the RB5 was no good in the wet in china. Horner said he knew exactly why the performance was not there in the car but he did not say what it was.
It could may well be the diffuser opening. The exhaust stream gets pretty noisy in the wet, on top of that, water will take take away some of the sensible heat from the exhaust, reducing the calculated effectiveness of the diffuser.
This idea has been floating around in my head for a while. While I am sure it helps with downforce generation as well (by either increased mass flow rate or energizing the boundary layer), I was thinking more along the effect on the engine of this system. Back pressure in the exhaust system is detrimental to engine performance, with every 7.6kPa taking away roughly 1% top end power. By putting the exits in a high velocity, you lower the total pressure that you are fighting against (Ptotal=Pstatic+.5*density*velocity^2). In the case of exhaust exiting parallel to the outside high velocity air, the dynamic pressure actually takes away from the static pressure. This lowers your back pressure and, as a result, your pumping losses.vonk wrote:
IMHO, the exhaust mass flow is a function of the power produced by the engine regardless of its RPM. So it’s throttle dependent. You could use the exhaust flow to somehow increase down force or you could use the diffuser to “suck” on the exhaust for better engine breathing. This would reduce the diffuser down force where the exhaust comes out, so it is segmented off from the rest of the diffuser bottom (arrow). Like most tricks, it’s a trade-off, but helpful down the back straight.
