WhiteBlue,WhiteBlue wrote: Current injection technology isn't fast enough to create layered charges by multiple injection events...
Actually, modern direct-acting piezo injectors can achieve very high frequencies (ie. single injection events of .10ms or less). In production diesels, it is now common to have up to 5 discrete (pre/main/post) injections per cycle with a 5000 rpm engine. GDI injectors tend to use much longer injector PW's due to the much lower rail pressures used and the larger mass of fuel that must be delivered per injection.
GDI injectors could go to higher rail pressures in order to improve spray atomization and reduce injection PW. But accurate control of fuel mass delivery becomes problematic with higher rail pressures. Gasoline engines must operate over a fairly narrow range of equivalence ratios, and thus require precise metering of fuel based on measured intake air mass flow. Diesel engines are insensitive to equivalence ratio, so super-accurate fuel metering is not so critical and extremely high (2000 bar) rail pressures can safely be used.
Regards,
riff_raff
