http://www.worldlingo.com/ma/enwiki/en/ ... 000_seasonAntônio Pizzonia was disqualified from second place in Italy for running a rear wing element upside-down.
I am not sure that particular wing would but some of them were running up to -6 aoa I just grabbed a picture of an Indy wing from this yearhorse wrote:^ I'm not sure that the above profile would generate lift. The trailing edge is pointing up, so the resultant flow will be producing an upwash and therefore downforce. This sort of profile is kinda like an aircraft wing when it is cruising, i.e. a low lift/drag solution, but in this case low DF/drag.
richard_leeds wrote:You can attempt to set a land speed record anywhere you fancy. The current record was set in Black Rock Desert (Arizona), not in Bonneville (Utah). http://en.wikipedia.org/wiki/Land_speed_record
The trouble is that you need enough space to speed up, hold the speed for a mile, then slow down & turn around for the return run. The current record holder needed a 13 mile track. http://www.thrustssc.com/Runs_Database/Run66.html
You also need a space that is flat, free from debris, and hard enough to support the vehicle. Dried salt lakes are ideal because they are flat having been lain by water, and water tends to be flat! The dried salt is hard, and there is no vegetation.
Conventional deserts can also be successful locations, more info here http://www.thrustssc.com/thrustssc/Loca ... tions.html
Of course Bonneville has history & tradition so they have lots of knowledge about conditions and how to create the track. I think that's why it attracts teams wanting PR.
Purpose of the tail is not downforce but straight line stability. A Sharkfin engine cover would have server the same purpose, but that innovation was introduced in F1 only in 2008 by Redbullagungn51 wrote:richard_leeds wrote:You can attempt to set a land speed record anywhere you fancy. The current record was set in Black Rock Desert (Arizona), not in Bonneville (Utah). http://en.wikipedia.org/wiki/Land_speed_record
BAR Has done it on Bonneville.
But how can it generate downforce with such wing ?
Indeed. And the car's underbody and tyres are providing sufficient traction to stop the rear wheels from spinning. If you're just heading in a straight line, what more do you need?WilliamsF1 wrote:Purpose of the tail is not downforce but straight line stability. A Sharkfin engine cover would have server the same purpose, but that innovation was introduced in F1 only in 2008 by Redbull
This one will go down to the records, coming from a Dane at that! Xactly where do you figure the propulsion-force to overcome the aerodynamic drag comes from, if not from the tyres to the ground?hollus wrote:Mostly spent on drag, though, and hence never transmitted through the tyres to the ground.
What's wrong with being a Dane?xpensive wrote:This one will go down to the records, coming from a Dane at that! Xactly where do you figure the propulsion-force to overcome the aerodynamic drag comes from, if not from the tyres to the ground?hollus wrote:Mostly spent on drag, though, and hence never transmitted through the tyres to the ground.
The Honda rear fin moved to aid steering and stability it wasnt fixed like redbulls and todays sharkfinsWilliamsF1 wrote:Purpose of the tail is not downforce but straight line stability. A Sharkfin engine cover would have server the same purpose, but that innovation was introduced in F1 only in 2008 by Redbullagungn51 wrote:
