No, as Suzuka had long straights too and the McLaren was nowhere.Gerhard Berger wrote:I think it will be very close between the top 3. There's sections of the track which suit each car. The long straights will help Mclaren, there are a number of heavy braking zones which suit the Ferrari, and there are also a number of longer medium speed corners which will suit the Red Bull. If Red Bull do end up behind the Ferraris/Mclarens, they will have a tough time passing them.univex wrote:From turn 6 to 18 seems to be good for RBR given the amount of medium and high speed corners.
RBR to lock out the front row, just.
However given the long straight at the start they are going to have a hell of a time keeping maccas and ferraris behind off the start. Maccas will be particularly quick off the start, although the ferrari should be just as good down the straights and the best in the breaking and traction in turns 3 & 4.
A bit like SPA IMO. RB's should be quickest, though I can't see them getting passed the maccas and ferrari's
Start of the race LH and FA to pass the Red Bulls. RB will suffer when they get within 1.5 secs of the car in front. The undercut from the new tires will be too much advantage to stay out on the softs and make up the time. Tough race for RB.
Also, Renault could spoil the party for one of the big boys.
Mclaren wern't "nowhere" - Hamilton qualified 3rd (was the best of the rest if you like).wesley123 wrote:No, as Suzuka had long straights too and the McLaren was nowhere.Gerhard Berger wrote:I think it will be very close between the top 3. There's sections of the track which suit each car. The long straights will help Mclaren, there are a number of heavy braking zones which suit the Ferrari, and there are also a number of longer medium speed corners which will suit the Red Bull. If Red Bull do end up behind the Ferraris/Mclarens, they will have a tough time passing them.univex wrote:From turn 6 to 18 seems to be good for RBR given the amount of medium and high speed corners.
I am sure of this track being an red bull track
After the 2 straights it is all just Red Bull territory with fast sweeping corners and medium speed corners. Even if McLaren gains half an second on the straights the red bull will gain one second on the rest of the track.
The difference is, Abu Dhabi is a very stop start circuit, with a lot of 2nd to 3rd gear turns (aside from the 2 long atrights). Korea has some flowing corners, like Spa, and long straights which will leave you as a sitting duck by running too much wing.raymondu999 wrote:I would've figured that Abu Dhabi was closer to Korea than Spa...
It is similar in a way, but i think Abu Dhabi lacks the longer, medium speed corners.raymondu999 wrote:I would've figured that Abu Dhabi was closer to Korea than Spa...
F1 Sporting reglement wrote: d) At each Event seals may be broken once, under supervision and at any time prior to the second day
of practice, for the sole purpose of changing gear ratios and dog rings (excluding final drives or
reduction gears). Competitors must inform the FIA technical delegate which ratios they intend to fit no
later than two hours after the end of P2.
Gear ratios and dog rings (excluding final drives or reduction gears) may also be changed under
supervision for others of identical specification at any time during an Event provided the FIA technical
delegate is satisfied there is evident physical damage to the parts in question and that such changes
are not being carried out on a systematic basis.
Odd comment, given the results of the last few races?ringo wrote:ferrari is third best now. The Mclaren seemed to improve since suzuka.
