Hi Terry,
Thanks for your reply. You have a point, but I think, it´s a bit more complex then just that. And there are cases where the shaft diameter is not only defined by bearing load capacity.
I don´t want to take the thread off it´s aim, so I will keep it short.
I was not talking about cam follower rollers. I was talking about rocker bearings. Now, why it was wrong to say ,almost any engine uses them, there use is not that uncommon either.
A GM LS7 engine or a BMW motorbike engine come to mind, you will also find many aftermarket kit´s for US big/small block V8´s containing this type of bearing (for better or worse), and the fact that larger OEM suppliers using this in there products, makes me think, that it is at least not gross engineering oversight to use them.
There are surely advantages for plain bearings, especially when they can be used in an hydrodynamic application, such as 4-stroke ICE which provides a clean and pressuriezed oil supply.
If this is not the case, I think meedle bearings are quite commonly used in 2-stroke engines as piston pin bearing and in tripods and yoke joints for drive train applications.
Here is an excerped out of "Advanced Automotive Technology" in regards to the general matter.
So at least it seams to be still open to discussion.
If you and Marcus want to draw the conclusion that a plain bush (DU bush) is the only or engineering wise superior solution for an suspension rocker, then that´s fine with me, but I won´t agree with that.
And that´s where we started out.
Before we discount an needle or roller bearing off hand as ignorant engineering, we may need to consider it a little bit more - IMHO.
I agree that contermination inside an roller/needle/ball bearing is not beneficial, and will harm the performance and shorten the life span.
But, I´m reasonable confident, that these problems can be overcome successfully, and don´post a too great challenge.
If the load is applied in radial direction, with only a small side load component, I don´t find much wrong with the use of a needle bearing. As you will find in many motorbike rear suspension rockers for damper actuation, even on off- road bikes.
If the sideload component is high, or we have a combined load vector axial and radial, other bearings, such as tapered roller or ball bearings, are a better choice - IMHO.
I would not have thought, that a plain bearing is a good choice under this conditions.
But I´m open to learn and will accept a good explanation, but contermination with carbon dust and possible water ingression and corrosion, did not convince me of it.
Sorry
Finally, to contribute something meaningful to the thread, these are types of spherical bearings which are used in push/pull rods and dampers to minimize friction, especially under loaded conditions.
They are only used, where the main load is transmitted radial to the bearing, as in a push rod or a damper.
I don´t know, if these bearings are used in F1 pushrods, they are used in sports/GT and Touring cars, if the teams can afford them.
I´m sure Terry has come across them in his field of work as well.
As Dave pointed out, friction per se, is not the problem, as long as it is constant and does not change with conditions. Here lies one of the draw backs of plain bearings and rod-ends/ball joints. There friction varies greatly with load and load direction, as well as with temperature etc.
Finally, I would like to thank Riff-Raff,Marcus,Dave,Belatti,JET,mep,pup,Flynfrog and many others for a nice time here on this forum, and for interesting and stimulating discussions.
Due, to some recent developments (not related to this thread)I wont be able to participate longer on here.
I hope you have a nice time & take care
Ciao
747heavy
