Sauber C30 Ferrari
Byronrhys
Re: Sauber-Ferrari C30
Its going to be Blue and white for sure :lol: Two major sponsors confirmed in that colour and if panasonic comes on board that'd make strike three.
Byronrhys
Sergio's seat fitting in the C30 and there new seatbelt supplier Takata.
A lot is covered but do I see a U section on the form? The nose also looks like its going to be low.
Yes maybe a U shaped nose...
The radiator entry are bigger than those from the C29 witch has been built around the BMW engine. The Ferrari effect ? C29's look suggest that its radiators weren't large but the Ferrari 'made' them longer.
This C29 will maybe have larger but shorter rads.
scarbs
scarbs
393
Its definitely a "V" nose, you can see the shaped underside on the high res pics here (http://f1.f-e-n.net/index.php/url28393). Curious they've hidden the undercut on the roll structure, not much to hide when they had one on 2010? Has that roll structure been rapid prototyped, it seems a large piece for such a process.
Indeed.
What are those small tanks located in the bottom of the sidepods. The 2009 Sauber had the same...
Kersed F1.09
http://img209.imageshack.us/img209/482/bmwf109kers.jpg
Not Kersed F1.09
http://img232.imageshack.us/img232/8779/d09esp173.jpg
scarbs
scarbs
393
Pressurised nitrogen tanks for the pneumatic valves
Nitrogen :shock: are they allowed to use it to cool the KERS ?
dan928
dan928
c29
forty-two
Did anyone else notice that the tyres in the original shots are unbranded (or airbrushed, although I doubt it as they have red dots on them and I don't think they'd have bothered to "insert" those when airbrushing) and the final image clearly shows Bridgestone's?
Byronrhys
forty-two wrote:Did anyone else notice that the tyres in the original shots are unbranded (or airbrushed, although I doubt it as they have red dots on them and I don't think they'd have bothered to "insert" those when airbrushing) and the final image clearly shows Bridgestone's?
If you mean the photo above yours That's the C29, Kamui's first seat fitting.
here is Kamui's 2011 C30 seat fitting with some more interesting shots.
Holm86
249
Are they hiding an extra air-intake underneath the airbox with all that tape?? Perhaps a cooling intake for the KERS?
it's just a mock-up guys.. That aint no C30.
forty-two
Byronrhys wrote: If you mean the photo above yours That's the C29, Kamui's first seat fitting.
DOH! Yes, I did mean that, and you're absolutely right, my mistake!
n smikle wrote:it's just a mock-up guys.. That aint no C30.
The mock up is certainly very close, if not identical, to the real chassis.
And this incomplete chassis is too 'interesting' to be a false approximative chassis...
ESPImperium
ESPImperium
64
It isnt a mock up. Sauber have traditionally had chassis number 01 as the one they do the seat fit in. Mercedes are a team that do the same.
Some teams use mockups like McLaren and Team Lotus, others use chassis 01 as the real deal as then they can make changes to 02 and onward if needed. As you can see they have already changes the air box from the BMW era traditional straight triangle to the short tubby triangle.
The chassis is about 5-7 days away from being finalised by those pics, they have probably a couple of refinements id recon to do, mainly arround the airbox would be my hunch.
