![Image](http://i805.photobucket.com/albums/yy338/aklracing/wrcgbox.jpg)
As far as I understand it, the drivetrain/gearbox is based on S2000, just the engine is a 1.6 I4 turbo now. There is no center diff, and the front and rear LSD´s can only have mechanical locking (ramps/friction plates).
Visco couplings are not permitted.
So, I would like to think, that the Xtrac value of 50/50% still holds some weight,
put I can´t say 100% for sure.
There will be a convnetional sequential/ or H-pattern g/box - no pedal shift at the steering wheel.
And the handbrake cut off for the rear axle, is via an hydraulical activated clutch (like in the mid 90`s), very simple concept/system.
In the article it says that power of the new engines is ~50hp less then the current 2l turbos and torque is said to be at ~50% of the current engines.
The engine must have direct fuel injection
max. body width of the cars is 1820 mm.
