![Image](http://i40.tinypic.com/29pr9es.jpg)
That's the welded chassis. 1.75inches x 2mm wall thickness, ERW(sae 1010) steel tubing.
We will add triangular reinforcements in the roll cage, to assure its integrity. We'll do this since some of the fittings were not perfect(gap between tubes) and we're not professional welders.
The little box in the front gets 4 suspension pickup points in the corners. The rear gets semitrailing arm with a suspension right on the corner of the floor. The other pickup points goes along the floor back tube, such pickup points lacks reinforcement.
The engine compartment is huge, but we thought it looked more proportionate that way. It will accommodate a 1.3L I4 from a fiat 128, transversal with transaxle.
Any opinions.. how do you think it will turn out? Do you think is strong enough?
I've read they normally use 1.25'' x 3mm. We though bigger would be better so we went for 1.75. Weight / foot of the chosen tube is just 2% less than 1.25''x 3mm.
We've stopped a little because we have to study.
The suspensions have been already designed, we're just finishing the arms in solidworks and bought 1.25'' x 2.85mm tube for the A-arms. Front and rear coil-overs will be "home-made" since it's not easy to find cheap coilovers here in Argentina. (we just need to build a top plate).
Well.. I'll update soon when I have something new.
Bye!
Caito.-
