Which makes sense, at least in my headThe actual grip that a tyre can generate is dictated by the coefficient of friction of the rubber compound used in the tyre. The higher the coefficient, the more grip which can be generated. The relation that is used is called Amonton's Law
It carries on:
It goes on to state that the reason wider tyres are better is, that they allow for greater heat control, as there's a greater area for cooling. So wider tyres can use a softer rubber which in turn allows for a greater friction coefficient and more grip, without overheating and ruining the rubber.So, if you increase the weight on the tyre, then the frictional force will increase as well, in proportion to the increase in weight on the tyre - but the coefficient of friction will remain the same. The level of grip of the tyre (forgetting about suspension niceties - we are only discussing tyres here) is totally dictated by the coefficient of grip of the tyre and the weight acting on it - not the area of the contact between the tyre and the road.
Is the article correct in what it says? (I'm know not of what makes tyres great)
