Turkish GP 2011 - Istanbul
MrBlacky
MrBlacky
Re: Turkish GP 2011 - Istanbul
Didn't want Pirelli to bring an extra hard tire?
Guys, where do you think the DRS zone will be?
240
I'd say detection at turn 9 and activation 60m or so after turn 11.
volarchico
volarchico
Any chance they might activate DRS before turn 11?
raymondu999
Anyone know the length of Turn 10-11 and 11-12? I think we could measure things by backtracking 750 meters form Turn 12?
失败者找理由,成功者找方法
volarchico
volarchico
About 730 m from the apex of T11 to the start of T12.
raymondu999
I think tyres will dominate the discussion of this race again. Traditionally in Turkey temps have been quite high, no? I'm actually slightly afraid, with hot temps, and T8. I think 3-stops is fine, but 4 stops as the norm will be too much. I want to see organized excitement and not mickey mouse "huh? What just happened?" ignorant excitement
失败者找理由,成功者找方法
volarchico
volarchico
Maybe the higher temps will help the tires last longer. T8 definitely won't!
beelsebob
beelsebob
85
volarchico wrote:Maybe the higher temps will help the tires last longer. T8 definitely won't!
Higher track temps at Malaysia certainly didn't help the tyres last.
It'll be interesting to see what the temperature is during the race weekend. If RBR are still suffering KERS issues (likely to be heat related, at least in part) then they might struggle even if they are quickest through T8. McLaren appear to be over cooling their car - maybe revisions will be in place by Turkey that reduce the cooling and potentially improve the car's L/D (meaning they can run a bit more wing without losing top end speed). This might put them closer through T8 and thus closer in overall lap time to the RB7.
Will Ferrari be able to bring more speed to their car in the next 3 weeks? Will Mercedes carry their form from China in to the potentially hotter Turkish race?
This could be quite an interesting race.
Giblet
Giblet
It used to be Spa's Eu Rouge that was the tipping point. Cars could either run it flat out or not. Now all proper cars can do it flat out with no lift.
Turkey's turn 8 seems to be the new litmus test. With the loss of DDD, I wonder if any of them will be able to take it flat out, all of them, or a mix.
China had that long straight and DRS which makes the pole lap not really comparable to last years, and just because qualifying might be faster this year, from what I understand the cars are still down on over all downforce from last year.
Shrieker
The race is held on 8 May. The temperature will be higher than in China, but it'll be nowhere as hot as Malaysia. The first race at Istanbul Park was held in August - which is a traditionally HOT time for Istanbul so I think people tend to assume it'll be a HOT HOT race.
It won't be. Mid May temperatures are rather mild in Istanbul.
Here, these will help too:
http://www.allaboutturkey.com/iklim_ist.htm
http://weather.uk.msn.com/monthly_avera ... c:TUXX0014
http://www.greatistanbul.com/climate.htm
-Atatürk
i70q7m7ghw
i70q7m7ghw
49
andrew wrote:Image
Why have you used a map that doesn't have the corner numbers? Crazy :roll:
zgred
i70q7m7ghw
i70q7m7ghw
49
Fantastic, as always zgred, nice work ;)
