Williams FW35 Renault
Re: Williams FW35 Renault
Barcelona Session 1 - Day 3 (21.02.2013)
zoro_f1
-2
yesterday on day 3 from barcelona testing (21.02.2013) they removed the illegal part of coanda effect :?: is this bad angle to figure it out :?:
Image “The force can have a strong influence on the weak-minded”: [Obi Wan Kenobi]
k.ko100v
k.ko100v
zoro_f1 wrote:yesterday on day 3 from barcelona testing (21.02.2013) they removed the illegal part of coanda effect :?: is this bad angle to figure it out :?:
http://i49.tinypic.com/2mnomx5.jpg
Nope, they are still there. :)
Barcelona Session 1 - Day 4 (22.02.2013)
High-res:
http://www.formule1.nl/media/uploads/me ... 151.67.jpg
Again with the old FW and Jerez nose... i wonder what's going on...
Huntresa
Huntresa
Sevach wrote:Again with the old FW and Jerez nose... i wonder what's going on...
Its you know testing :P
Perhaps they should test the new stuff as well...
zoro_f1
-2
the suspicious wheel nut... they made a commercial from that. Image
Forza
238
Williams tested two different shapes of DRS actuator housing
F1 test - BCN T02 - day 2
BCN T02 - day 3
Matt Somers
Matt Somers
179
Lets remember that Williams pioneered the Scopeless Brake Ducts which means they don't necessarily need the large ducts they have now. (Ie they are simply using the additional airflow from the larger brake duct for the axle vent)
Blowing out of the wheel in this way should help tidy up the airflow along the edge of the floor which in turn should help gain some more rear downforce. The problem is if it isn't done properly it can do more to hamper performance than improve it.
foxmulder_ms
foxmulder_ms
Dat front wing!! Really nice curves :) This car and Sauber have really nice features.
Barely anyone has bought new stuff to the tests. They mostly do that in the last test.
Apart from that, I cannot remember a 3 plane cascade being test/ran last year, so it is actually new for the wintertests
N12ck
Had a thought about the williams exhaust, this is what I think the intention was:
http://mcdowellf1.blogspot.co.uk/2013/0 ... water.html
enjoy
Budding F1 Engineer
markp
markp
Your idea is reingesting exhaust gases into an enclosed piece of bodywork in this case a pipe which is ileegal
