I feel like there's a point in here where andylaurence, being of an understated nature did not make clear that what he was talking about was not hypothetical. The picture is of the hot blown diffuser of Nic Mann's 'Manic Beattie' (which as it happens, i posted earlier) which uses the turbine starter unit or 'APU' out of a helicopter to run the turbocharger. It's sort of like a Napier Nomad that way, but with a much higher mass flow than a normally turbocharged Ford BDA could ever produce(even in your F1-esque hypothetical scenario autogyro), so Nic put it to use blowing the whole diffuser which is the full width of the car.autogyro wrote:Of course but you could use an ERS-H motor generator solely in motor form to blow from the turbo no matter what engine revs you had. No lag and plenty of air for the diffuser at all times and with much lower weight penalty.tomazy wrote:Electric hybrid doesn't have exhaust gases to blow the diffuser, turbine engine doesautogyro wrote:
You could do something similar with an electric hybrid Andy.
Super caps for E storage and a ERS-K in generator mode (overrun) only.
http://www.gtplanet.net/forum/threads/m ... ar.299951/
