The data was produced by a "bicycle" model driven by a typical vertical input. A front inerter was added (corner or 3rd, as you wish) to a typical suspension set-up of a GP2 vehicle. The rear axle had no inerter. Other suspension parameters were unchanged. Here is a an equivalent plot of the rear axle contact patch load time histories (same notation).gixxer_drew wrote:Dave, in this example you said inerter fitted to the front axle I assume you mean to the front third, yes? So this is a heave mode only test of just the front suspension, I'm not sure what you can talk about freely here, but what was the rear doing in this test?
For the sake of completeness, here is an estimate of the "straight line" energy dissipated by the tyres for the four cases (red front, green rear).
