So you think I should explain the reason active aero intended to increase DF would increase DF?bhall II wrote:To claim something is certain means you should be able to point to hard data that supports your conclusion. So, let's have it.
For that matter...
To claim something is possible, let alone "easy," means you should be able to explain the science behind it. So, let's have that, too.Andres125sx wrote:...IMHO we know more than enough to solve this part of the problem, as easy as implementing active aero to increase DF potential when in dirty air
Yes, we've once again reached the portion of the program where it's incumbent upon you to put forth more than a thesis statement. You have to explain the specifics of your ideas.
Do I need to prove a wing generate DF?
Do I need to prove a fan car generate DF without wings?
Do I need to prove ride height is a very important parameter for GEs?
As said previously, I´m not inventing anything, I´m only proposing active aero to increase DF. Since I´m not aeronautical engineer, I´m not proposing any specific solution because I don´t know what will be better, but I think I don´t need to be AE to know active aero can increase DF as dramatically as the rule permit it, because there are a million restrictions in the aero department, so if we want to increase DF it is as easy as removing some restriction/s
BTW, the easy part is modifying the rules to increase DF, not modifying the cars
To me more precise, it´s not clear how much increase in DF would cause active aero, but you can´t seriously say we don´t know if active aero will increase DF.bhall II wrote:Just to sorta move things along: it's not clear how a fan car can maintain aero balance when running in another car's wake; it's not clear how active aero/suspension can increase downforce when running in another car's wake; and it's not clear how anything that doesn't standardize a significant chunk of the car will have any effect at all.
I agree we don´t know how much improvement that will cause, but there will be improvement anycase. Thinking otherwise would be like thinking a car without wings will be equally fast when in dirty air to a wing car
Basically you´re negating aero use when in dirty air, like if dirty air would be the space where aero becomes irrelevant. We all know in dirty air aero efficiency go down dramatically, but it still works, not as planned, but still better than a car without aero, so if you increase aero, DF will increase too
