We actually did change the power half way through last season:
For the high downforce races we had 600bhp +160bhp KERS. For the mid/low downforce races we had 540bhp+KERS. This was to promote a more efficient design in the later races. In both cases all power was distributed to the rear wheels.
For next season we're likely to have a similar set-up although I am working on some adjustments such as a variable tyre wear rate model and a fuel allowance per lap, just like the real LMP1 class.
At the end of the day all these parameters do is affect the trade off between drag and downforce at any particular track...(the lines of "constant lap time" if you plot the test track results on a graph of drag vs downforce).
Rest assured that once we've started on a particular "block" of tracks (either high downforce, or low drag, etc, which have each been carefully selected so they have a very similar aero trade-off) I won't play with any parameters which affect the trade-off between drag and downforce without a big warning, and most likely no change will be made at all.
EDIT: good ide though, a page with information about the mechanical aspect of the car would be interesting. I'll put this together.
For example, I bet you guys didn't know that the cars have active suspension so that the attitude of the car (pitch, roll, heave) doesn't change during acceleration, braking or cornering so that the aero coefficients achieved in testing are the ones that apply throughout the entire lap ( There is no change in ride height or inclination during braking, for example),
