I know the team used them back when they were called Minardi...
wikipedia wrote:Disc springs has a number of advantageous properties compared to other types of springs:
Very large loads can be supported with a small installation space,
Due to the nearly unlimited number of possible combinations of individual disc springs, the characteristic curve and the column length can be further varied within additional limits,
High service life under dynamic load if the spring is properly dimensioned,
Provided the permissible stress is not exceeded, no impermissible relaxation occurs,
With suitable arrangement, a large damping (high hysteresis) effect may be achieved,
Because the springs are of an annular shape, force transmission is absolutely concentric.
Usually machined anodised aluminium.
With the limited testing available now, would it be worth the investment in time and tec to 'just test' something?ispano6 wrote: ↑25 Apr 2018, 05:16Perhaps this might be a 2019 topic for STR14 but I was curious if whether STR Honda had considered changing their brake system from Brembo to Akebono. It seemed McLaren had an advantage under braking and I wondered how much the partnership was made possible with Honda being in the picture. STR probably prefers to stay with Brembo but Honda might suggest trying out Akebono. I don't have any data to show if one is better than the other or how many different brake system providers there are in F1.
If there is braking performance to be gained absolutely. It seemed to me, in terms of Formula 1 teams, an exclusive partnership for Akebono and McLaren. Haas had brake issues and appeared to have trialed different solutions. Could Haas' performance improvement be partially attributed to better braking and tire temperature control?Big Tea wrote: ↑25 Apr 2018, 19:04With the limited testing available now, would it be worth the investment in time and tec to 'just test' something?ispano6 wrote: ↑25 Apr 2018, 05:16Perhaps this might be a 2019 topic for STR14 but I was curious if whether STR Honda had considered changing their brake system from Brembo to Akebono. It seemed McLaren had an advantage under braking and I wondered how much the partnership was made possible with Honda being in the picture. STR probably prefers to stay with Brembo but Honda might suggest trying out Akebono. I don't have any data to show if one is better than the other or how many different brake system providers there are in F1.
If there was a known advantage in moving to another manufacturer it could be worth while, but for a possible advantage is it worth the investment?
