Haas VF-22
continuum16
49
Re: Haas VF-22
Might help explain the apparent competitive boost despite no (visible) upgrades. Good for them. Apparently the first big changes will come in France.
- Mark Twain
Re: Haas VF-22
Sieper
73
Re: Haas VF-22
Would this require a strengthened gearbox - engine connection. I could think FIA is not happy to see this.
Re: Haas VF-22
Sieper wrote:
30 May 2022, 18:39
Why not? That's exactly what it's designed for! #-o
Zynerji
110
Re: Haas VF-22
Best rear-suspension pic that I've seen on here! Bravo! 👏👏
Rodak
Rodak
37
Re: Haas VF-22
Zynerji wrote:
30 May 2022, 23:39
True about the pics! Sheared some bolts there, which is certainly a good way to dissipate energy; quite a clean break with surprisingly little visible damage to the box and suspension. This is the same gearbox et al that Ferrari use, isn't it?
Michael
Michael
Re: Haas VF-22
Is this the Ferrari rear suspension? Is this useful for competitors at all? How does it work, what are we looking at, etc.?
Re: Haas VF-22
Michael wrote:
31 May 2022, 12:34
Should be a Ferrari supplied part, yes.
I think the belleville washers (the spring that looks like it's made of rubber) are for heave(vertical) motion(someone please correct me if i'm wrong).
Re: Haas VF-22
Sieper wrote:
30 May 2022, 18:39
You see that all of the mounting points are intact. After the Grosjean incident, FIA instructed that the bolts are designed to break away at a certain load so that the some of the kinetic energy from the crash is severed (literally) from the fuel cell/chassis.
Sieper
73
Re: Haas VF-22
Thanks all for the input. I see a car in two halves and think, this seems not OK, but in fact, this is the best you can achieve, dissipating the energy.
SiLo
138
Re: Haas VF-22
Sevach wrote:
01 Jun 2022, 13:50
Michael wrote:
31 May 2022, 12:34
This is correct, so it doesn't impact movement when left and right are moving independently of each other (think going around a corner).
Felipe Baby!
JordanFiveOh
JordanFiveOh
Re: Haas VF-22
Where in the world does the clutch/input shaft fit into that casing? Trying to visualize it and there’s so much suspension stuff in the way!
chrisc90
Re: Haas VF-22
JordanFiveOh wrote:
01 Jun 2022, 17:12
I was thinking this myself looking at the photos. Where does the gearbox go or where is the shaft from the gearbox to the rear diff (mini prop style?)
It is quite interesting and seems away from what you would expect for power train sort of setup.
Stu
Re: Haas VF-22
chrisc90 wrote:
01 Jun 2022, 18:16
JordanFiveOh wrote:
01 Jun 2022, 17:12
I can’t see where it would go, but have they built it onto the rear of the engine (back-to-front from the conventional)?
Would it be considered as a part of the engine mass if they were to do so?
Potentially very clever interpretation if they have!!
Stu
Re: Haas VF-22
You cannot quite see low enough in the bottom of these two pics….
