Think about how far ahead they would’ve been last year with the engine working at full capacity and without the mid season rule changes…
I hope I’m wrong.
Photo from the back
There were rumours that the 2023 car development got hit hard because of the TD because they relied on that plankdeadhead wrote: ↑15 Feb 2023, 01:39My only worry is that this philosophy was developed for a set of rules that are no longer there.. it worked brilliantly until the TD kicked in last year and I’m guessing things are even more extreme with this year’s changes, so sticking to original design but for a different rule set might be the wrong choice, but we shall see.
I hope I’m wrong.
Photo from the back
https://ibb.co/3pGQMvW
Don’t see what the visible design philosophy has to do with the TD. We have no clue what changes have been made to the floor. Ferrari clearly didn’t touch the F1-75 after the French GP and had to limp through the rest of the season with the TD’s effects. This car shouldn’t have that issue.deadhead wrote: ↑15 Feb 2023, 01:39My only worry is that this philosophy was developed for a set of rules that are no longer there.. it worked brilliantly until the TD kicked in last year and I’m guessing things are even more extreme with this year’s changes, so sticking to original design but for a different rule set might be the wrong choice, but we shall see.
I hope I’m wrong.
Photo from the back
F1 fans have very short memories. Holes beneath the side pod inlets were around since the dawn of f1 hybrids(2009) and were always for electronics cooling..
Those are far larger than anything electronics cooling would require.PlatinumZealot wrote: ↑15 Feb 2023, 05:54F1 fans have very short memories. Holes beneath the side pod inlets were around since the dawn of f1 hybrids(2009) and were always for electronics cooling..
What does this answer?
Indeed they are. I took a look at camera pods, but did not notice this. Looks like an attempt to stack the pods and upper suspension arm to reduce overall drag slightly. With stiff suspension and little movement, this should yield even better results.
I remember 2004 well, when the press and Scarbs said the F2004 was disappointing and that a car with so little development would have little chance against the extremely advanced McLaren, Renaults or the "ingenious" Williams with its Walrus nose. When the F2004 then drove everything into the ground it was quite embarrassing.... once again it had been shown that knowledgeable and continous development is the key to success.deadhead wrote: ↑15 Feb 2023, 01:39My only worry is that this philosophy was developed for a set of rules that are no longer there.. it worked brilliantly until the TD kicked in last year and I’m guessing things are even more extreme with this year’s changes, so sticking to original design but for a different rule set might be the wrong choice, but we shall see.
I hope I’m wrong.
Photo from the back
Maybe we're both right. That the suspension is generally higher does not necessarily exclude what you think you have seen. But hopefully that will soon become clear!Giando wrote: ↑15 Feb 2023, 00:40Yes, obviously i am going to be wrong and you are going to be absolutely right.Andi76 wrote: ↑15 Feb 2023, 00:09You are wrong. You can clearly see on the mounting points of the chassis that the suspension is higher. And by now I'm not the only one who has noticed it. Piola and Hughes have also just reported on it a few minutes ago. The bulge on your pic it is rather unclear and it is not at all recognizable what this actually is.Giando wrote: ↑14 Feb 2023, 23:36
I'm sorry but, actually, a front picture isn't the best to judge and compare the respective height of two elements such the front and rear arms of a wishbone... because one is much closer to your view due to the perspective and the other one is more distant... so, it's more likely that such a picture could deceive you.
The side photo i posted instead clearly shows some bulge in the lower part of the chassis shell.
I might still be wrong of course![]()
Because it's very unlikely that only i could have spotted such a peculiar solution.
Nevertheless, I'd love to see more pictures because in that area the shape of the chassis is really different compared to the F1-75. There's a radius in the edge of the carbon shell which i don't understand...
Oh, by the way, i'd like to add another photo to the discussion, which is very interesting.
Let me know. Thank you.
https://postimages.org/
I totally agree with you! Scarbs is excellent! But that what he has said here simply lacks any basis and moreover completely contradicts what history proves concerning knowledgeable, continous evolution.Chuckjr wrote: ↑15 Feb 2023, 08:36Your comments are valid 76.
Re Peter and Scarbs....my only criticism is their unabashed bias towards Merc and Lewis, and their often poor pre-season predictions. I mean, Windsor was almost in tears over what happened at the end of 2021. And your comments here epitomize well their poor pre season predictions. I also remember Scarbs being unimpressed with Ferrari last year pre-season. Anyway, if you can see past their biases and predictions, they often have a lot of insightful things to say — especially Scarbs. That’s been my experience watching them for years now.
IT seems they as RB went with sloped upper wishbone. Compared to last yearGiando wrote: ↑15 Feb 2023, 00:40Yes, obviously i am going to be wrong and you are going to be absolutely right.Andi76 wrote: ↑15 Feb 2023, 00:09You are wrong. You can clearly see on the mounting points of the chassis that the suspension is higher. And by now I'm not the only one who has noticed it. Piola and Hughes have also just reported on it a few minutes ago. The bulge on your pic it is rather unclear and it is not at all recognizable what this actually is.Giando wrote: ↑14 Feb 2023, 23:36
I agree Andi, in fact my previous comments weren't aimed at demonstrating that the suspensions arms - in general - are mounted in a higher or lower position than last year on the SF23, thus pointing out that something has changed in the area where the lower wishbone's rear-arm connects to the chassis.Andi76 wrote: ↑15 Feb 2023, 08:36Maybe we're both right. That the suspension is generally higher does not necessarily exclude what you think you have seen. But hopefully that will soon become clear!Giando wrote: ↑15 Feb 2023, 00:40Yes, obviously i am going to be wrong and you are going to be absolutely right.Andi76 wrote: ↑15 Feb 2023, 00:09
