Amazing to see all these cars popping up today, looks like we will be having a great competition again this year!
I've only been able to create a very primitive design so far, but have some trouble to run it through MFlow.
MFlow states that a build has not been created, but a "runCase.sh" does appear in the map.
I've tried running "runCase" within OpenFOAM, but to be able to make that work I had to change every instance of "mpirun" to "mpiexec" within the runCase-file.
After this, OpenFOAM does seem to do its thing, but it runs into errors during the process.
OpenFOAM crashes after not being able to find a PatchField entry for the RHS heat exchanger, even though both the heat exchanger bodies and heat exchanger planes are in the right corresponding folders:
--> FOAM Warning :
--> FOAM FATAL IO ERROR: (openfoam-2106)
Cannot find patchField entry for none_to_hx_right
I'll try some troubleshooting in the coming weeks, hopefully I will be able to create a working car this season!
