alelanza wrote:A question that's always bugged me and never got a good answer for, is wheel slip a function of wheel power or wheel torque?
Now it gets messy....
If you look at this chart below (I made this for another post, so ignore the pink arrows!) it shows force at the wheels for a car with 4 gears. The shape of the force curves is the same shape as the torque curve, so taking 4th gear as an example, the force at the wheels is highest at about 90mph, and therefore it is most likely to spin its wheels at that point (highest torque), rather than any other point in the speed range
in that gear.
So now you'll ask, "if the force is greater, surely the acceleration is higher than in the same gear at maximum power (higher up the rev range)?" And the answer is "yes" -
in that gear, however you can also see from the graph that for
the same speed (assuming that there IS enough grip) it is better to drop down to a lower gear (gear 3) and increase the engine speed where the torque x speed (power)is greater, because it generates more force (and hence more acceleration)
at that road speed....
