andrew wrote:I saw a while ago that hydrogen is already being used in the US and is doing quite nicely. Electric is a pipe dream. Electric cars have poor range and take far too long to charge. The there is the increased demand for electric, much of which is generated from coal or diesel fired power stations. Hydrogen is one of the most common substances around and refining it into a usable form for automotive technology is no harder than refining petrol. The only thing that comes out the exhaust in water so it is a win win situation. The hippys will love it as well as those of us who don't believe in global warming being caused by cars.
Did we sleep during physics class?
Hydrogen is not a primary energy source, it is simply used as an energy carrier. There is no 'free' hydrogen availbile and refining it into a usable form would be nothing like oil.
Hydrogen have to be produced from for instance water taking the energy from a primary energy source such as solar, geothermal, uranium/thorium, biomass, coal, natural gas or oil. Currently, the only realistic method to produce it in larger quantities would be from fossil fuels; coal, natural gas or oil and that will in most cases be uneccesary, it would basically be simpler to use the fossil fuels directly and save the conversion losses.
andrew wrote:Add to your list, capping engine size at say 2 ltrs. No one needs an engine bigger than that for everyday use. Also, set minimum miles per gallon targets at something like 30 - 35 miles per gallon.
Big engines are nice but man to the drink heavily!
That would be counterproductive. It is better to follow the current legislation with corporate average fuel consumption/CO2 emissions limits.
You could something similar with fuels. Say that an oil company is selling X TWh worth of transport fuels, then say 5% of that have to be reneawable. If they fail to comply they will be fined, and over time, the renewable component will increase. There could also be restrictions on the use of foodstuffs as the renewable source.
Biomass gasification can be used to convert theoretically any biomass into synthesis gas, and from there several possebilities exist. It is possible to directly produce methanol, which can be used as a fuel or a fuel component. Methanol can also be converted to DME, a diesel fuel, or gasoline using ExxonMobils Methanol To Gasoline (MTG) process which can be directly blended into gasoline at any proportion. Synthesis gas can also be converted to Fischer-Tropsch wax, which can be used as a raw material for a refinery similar to crude oil.
There are also a few ways to modify vegetable and animal fats to diesel grade hydrocarbons, which do not have the quality issues like fatty methyl esters and raw vegetable oils.
The conversion efficiency of biomass to diesel fuel using Fischer Tropsch is roughly 50% + waste heat suitable for central heating.
Of course, neither is currently capable to replace oil, but it would be a big improvement over first generation biofuels such as ethanol and fatty methyl esters.
xpensive wrote:I'm sorry, I can't really follow here WB, concrete now, which BMW Gasoline-TC models can I buy at the moment if I wanted one?
What a TC does is packing more oxygene-molecules into the engine, helping it burn as much fuel as a larger atmo-engine, where the obvious gain would be less internal friction and less fuel consumption in the lower part of the power-band, but other than that I can't really see the efficiency advantages if you really use the power available, like in a racing engine?
Besides, the TC is not running for free, it will create a back-pressure on the xhausts comparable to the boost, depending on turbine sizes.
Turbocharging will solve the main issue with current car engines; the fact that they are oversized for their application. When we build a car we have to chose an engine that is strong enough to provide an acceptable acceleration. This introduces the problem that to provide an acceptable acceleration, the engine will be forced to operate at a very low load during most of the driving cycle. The average bmep ends up just being around one-two bar and at such a low load the efficiency of the engine will be really low since we spend about as much power turning the engine around as powering the car.
With turbocharging we can install a much smaller engine in the same car, increasing the average bmep, and still being able to produce the peak power required for acceleration. The result isn't improved peak efficiency, but a much improved engine efficiency over the driving cycle.
A turbocharger turbine is powered by what is sometimes called 'blowdown energy'. That is, when the exhaust valves opens late on the expansion stroke, the pressure inside the cylinder is still high enough that the exhaust gas will flow out by itself at a high velocity. The turbocharger turbine mainly takes its energy from this blowdown phase, and that the turbine adds a restriction won't have much of an impact on the engine. The turbocharger system is generally designed to take advantage of the pressure rise in the exhaust manifold that occur during blowdown, and then during the exhaust stroke the manifold pressure will sink rapidly, adding little pumping losses during the exhaust stroke. Ideally, the pressure would be atmospheric during the exhaust stroke although that isn't really realistic, the pressure can however be substancially lower then the inlet manifold pressure supplied by the compressor.
ISLAMATRON wrote:isn't most of the energy thrown out the back in the form of thrust? how efficient would it be in translating that through a turbine and into an electrical generator?
Jet engines are designed to operate moreso at high altitudes with tremendous volumetric flow, can they be efficiently used in a land vehicle operation... the only example that comes to mind is the M1 abrams... are there others?
Volvo built a few serial hybrids powered by gas turbine engines. The peak efficiency of the turbo alternator (fuel to electricity) was in that case just slightly below 30%. As they also were rather large due to the recuperator used to improve the efficiency of the engine, and were very expensive their only significant advantage was their cleaner exhaust.
A recuperator uses exhaust gas downstream the turbine to preheat the compressed air before the combustor.
flynfrog wrote:
The Abrams is by far the best suited tank to its environment. yes it drinks fuel but it is much faster and has a higher payload than any other tank.
To put a gas turbine in a main battle tank is a pretty dumb idea. What you gain in weight you will lose in fuel consumption, and you end up with a huge fuel distribution problem.
The large amount of hot air expelled by the engine is an easy target for a heat seeking missile. If the Leopard 2 detects that it is fired upon it can shut down it's cooling fans for a short period of time.
xxChrisxx wrote:
That's becuase it's not meant to be. It's designed to be a MBT, not to get you to the shops using the lest amount of petrol. The reason why they used a gas turbine was because it can run on pretty much anything. Petrol, Diesel, Kerosene, chip pan fat, you name it the turbine will combust it.
(The main idea was to save money by only using aviation fuel that they could steal from the planes).
And frankly it's interesting that you chose a wankel, which has to be one of the most dreadful engines to use in terms of efficiency due to completely shitty sealing. Power density, yes. Efficiency, no.
Why did you chose a wankel for 'efficiency'?
In war you really only have two fuels availible to you: jet fuel and diesel. Military diesel engines are capable to run on both, with jet fuel often used as a the standard fuel.
