N12ck wrote:No, there is mechanical grip, but however it is the main one, and f1 is alot about aerodynamics, putting a DF cap on would essentially standardize the aerodynamics other than striving for efficiency. Meaning mechanical grip would be the deciding factor which I dont believe is a good direction for f1.
Nicky
Downforce is not the sole performance parameter in neither general terms nor aerodynamics. In case the amount of downforce will be capped, teams will still try to improve that area in order to reduce aerodynamic drag and to get the allowed amount of downforce at the lowest speed possible, for example by using movable aerodynamic devices.
