2018 McLaren F1 Team - Renault
Re: 2018 Mclaren F1 Team - Renault
diffuser wrote:
09 Mar 2018, 12:52
The holes act like a parachut ...the rest the air just goes around
Not that simple, how much air flows through and how much cooling occurs depends not only on the intake size but the expansion ratio behind, the blockage effect from the radiators, the relative pressure difference at the intake to the exit, etc.
Large expansion ratio and bigger radiators means you're getting more flow and cooling even with a small intake, you can shrink radiators and sidepods but that causes more blockage which generally means you can't shrink your intakes much even with tighter, hotter running package - that's why even when we see teams bring new, tighter sidepods the intake area doesn't change much from the initial setup on the car.
A heat pocket by the turbo when the car is on slow laps/in laps/pitlane might even be fixed by tighter sidepods because you'd have relatively more/faster airflow up there, which is why it's not really a worry unless it's still doing it once they have the new package on.
marmer
marmer
Macklaren wrote:The fact that something so serious is recurring and the team are so relaxed about it leads me to believe that they know EXACTLY what the problem is and have a fix for it but for some reason can’t do it on the test car
Or they are bluffing while searching for some sponsor money.
I don't get this it will be ok by Australia with our new kit on
If they know it's better why didn't they bring that setup. What if they get to Australia and it's not better too late then because they can't go back to this set-up its got proven heat issues and it's not been that quick.
They can't bring something that's not made.
cyclon
-2
PhillipM wrote:
09 Mar 2018, 15:18
Exactly =D>
I guess we will see a bit of fatter bottoms car in Melbourne :oops:
I loved the iconic McLaren-Honda
But most of all i love McLaren . After all first contact made with M23 that had a Ford Cosworth PU
bauc
cyclon wrote:
09 Mar 2018, 15:20
PhillipM wrote:
09 Mar 2018, 15:18
Exactly =D>
They are back out, much quicker change
marmer
marmer
PhillipM wrote:They can't bring something that's not made.
Well virgin attempted to make a car on a computer and it was rubbish so until it's made and tested they have nothing look at red bull when they had issues with what the numbers told them and what they had on track
Redragon
19
cyclon wrote:
09 Mar 2018, 15:20
PhillipM wrote:
09 Mar 2018, 15:18
Exactly =D>
if the problem is cooling (that we don't know for sure) and the package for Aus is on the making any changes decided during this test will not see the light on Aus.
RonDennis
RonDennis
marmer wrote:
09 Mar 2018, 15:15
Because they use this test for correlation, so that they can make adjustements if something isn't right. It's all about having a good baseline. The car in Melbourne won't be a completely different concept. Just temper your expectations a bit, because they won't be winning any races this year. They just need a good year and if they finish 4th, they have done a good job.
cyclon
-2
Redragon wrote:
09 Mar 2018, 15:24
cyclon wrote:
09 Mar 2018, 15:20
PhillipM wrote:
09 Mar 2018, 15:18
Exactly =D>
I am quite sure they were already set for a change around the exhaust area.
And as I said earlier, tighter sidepods will naturally speed up the airflow in that area anyway.
RonDennis
RonDennis
PhillipM wrote:
09 Mar 2018, 15:33
McLaren used the recommendations of Renault and said they would design their own cooling later on.
bauc
RonDennis wrote:
09 Mar 2018, 15:34
PhillipM wrote:
09 Mar 2018, 15:33
Yes, this is the strangest thing, they implied that they will go with the safe option, as recommended by Renault
GoranF1
GoranF1
155
Force India is doing 1.18' s on medium...hmmm
bauc
GoranF1 wrote:
09 Mar 2018, 15:39
WRONG TOPIC!
Redragon
19
bauc wrote:
09 Mar 2018, 15:40
GoranF1 wrote:
09 Mar 2018, 15:39
WRONG TOPIC!
depending how you look at it. that time is a scary from a Mclaren point of view
