McLaren MCL34
M840TR
M840TR
313
Re: McLaren MCL34
AMuS
Re: McLaren MCL34
NiyolHuayra wrote:
30 Aug 2019, 12:46
Why would the go with even higher mounting point? Any knowledge on this?
Could be for more KPI to make the new pushrod system more effective, could simply be there's an aero advantage there that wasn't an option previously until they modified the pushrods because it compromised too much mechanically, etc. You won't really know for sure without chatting to the team or spotting complimentary updates.
Re: McLaren MCL34
M840TR wrote:
30 Aug 2019, 13:55
_cerber1 wrote:
30 Aug 2019, 13:53
Perhaps these are generators of a useful vortex. Well, or absolutely nonsense, this device serves as a heat accumulator from tires and brakes. :wtf:
Probably neither. But just maybe the latter by stiffening it up and increasing surface contact somehow.
From this image ...it clearly looks higher...
Jackles-UK
Re: McLaren MCL34
Unless it's a trick of the light, this photo appears to show a load-bearing mounting arm sheathed within the wishbone. I'd imagine that when under heavy load the mounting point will shorten and slide back into the wishbone rather than the previous setup where the mounting point was fixed atop the attachment point. Would a system such as this be legal (movable devices etc.)?
Zynerji
109
Re: McLaren MCL34
Do we still have max camber directives? I would expect a system like that would increase negative camber during turns...
CLKGTR
CLKGTR
98
Re: McLaren MCL34
Yes, Pirelli sets static camber limits for each race. For Belgium it is -2.75 degrees for the fronts and -1.50 for the rears.
Minimum static tyre pressures for Belgium are 1.656 bar (24 psi) for the fronts and 1.38 bar (20 psi) for the rears.
230
Re: McLaren MCL34
NiyolHuayra wrote:
30 Aug 2019, 12:46
_cerber1 wrote:
30 Aug 2019, 12:40
NiyolHuayra wrote:
30 Aug 2019, 11:42
Is this just a wrap or is it titanium?
https://radikal.ru
Titan
Looks like the steering arm is up there?
To remove it from the flow going to the bargeboards below?
Re: McLaren MCL34
Looks like they tested the monza rear wing ?
Good article...
https://it.motorsport.com/f1/news/mc ... 4524670/
f1rules
f1rules
588
Re: McLaren MCL34
lando back to old suspension
Dipesh1995
Dipesh1995
104
Re: McLaren MCL34
McLaren (and Renault) have gone back to the B spec PU for the rest of the weekend according to Chandhok.
Ground Effect
Ground Effect
Re: McLaren MCL34
Dipesh1995 wrote:
31 Aug 2019, 12:07
I just saw that, Sky said it doesn't appear it's ready to race, whatever that means.
Avocado
Avocado
Re: McLaren MCL34
What is the point of those brackets? What do they do?
f1rules
f1rules
588
Re: McLaren MCL34
Re: McLaren MCL34
They're just taking the engine penalty ready for Monza, same as Ferrari.
roon
roon
412
Re: McLaren MCL34
New front upright might be for structural improvement. Larger, not necessarily heavier, for bending resistance. The material choice for the cover is interesting. Polished metal? I would have expected a CF part.
ringo wrote:
31 Aug 2019, 05:47
NiyolHuayra wrote:
30 Aug 2019, 12:46
_cerber1 wrote:
30 Aug 2019, 12:40
https://radikal.ru
Steering arms are either side of the rack.
