Sauber C31 Ferrari
raymondu999
Re: Sauber C31 Ferrari
Ah. I took your use of the word setup as in car setup/tuning/optimizations
失败者找理由,成功者找方法
MIKEY_!
Fair enough really, I wasn't being very clear.
tok-tokkie
tok-tokkie
38
That air outlet could be taking air from somewhere on the front wing to maintain laminar flow there. Entirely conjection by me.
MIKEY_!
That could be allowed. I think it is more likely an exit for the cooling usually located in the nose. However they are 'oversupplying' the cooling system to get enough air behind that broken nose to prevent separation.
Byronrhys
Shakedown days are like tests, its filming days which have restrictions.
raymondu999
not the same restrictions though
失败者找理由,成功者找方法
horse
n smikle wrote:I think we could have three things here or combination:
1. drag reduction. higher pressure Air from under the nose or from the cockpit will fill the low pressure gap.
2. The signal hole for the front wing f-duct.
3. Just a simple device to create air circulation to cool the driver.
Personally, I think these two combined and it's very clever too, a much better concept that the RB8's CD slot.
So the wake of the kink will provide a nice little pull to bring the air through the cockpit, whilst that same air will reduce the impact of that wake. It will also cause a little lift, where I said it would cause DF before, as there will be a positive circulation set up through and above the cockpit.
Intego
New exhaust layout for testing day 3 (via Auto-Motor-und-Sport.de):
"Posts targeted only at expressing favouritism or dislike towards people are treated as spam. They can hence be deleted without notice and could invoke a warning to the poster." f1technical forum rules
shelly
shelly
136
Interesting features:
-exhaust position
-sidepod not undercut but touching the external edge of the floor instead
-large use of spread tow carbon
twitter: @armchair_aero
FrukostScones
162
Carbon
Carbon
Question re:
. Is 'spread tow carbon' stronger than 'regular'* carbon?
*regular carbon being of finer strands.
(Sorry, not technical)
KevlarUSA
KevlarUSA
I believe I've read on this forum that spread tow isn't as strong but it's easier to form into complex shapes.
gerishnikov
gerishnikov
If you are referring to the chequer board carbon, it is simply a hybrid if ud carbon running at 0 degrees and 90 degrees, often used on bodywork as it is stiff and light but its not very strong. Oh it is definitely not easier to form in to complex shapes regular ud, 2x2t or a 5h material would be much nicer.
Owen.C93
Owen.C93
177
Carbon wrote:Question re:
It's lighter for the same strength in most cases as well and is ideal for a "skin".
volarchico
volarchico
gerishnikov wrote:If you are referring to the chequer board carbon, it is simply a hybrid if ud carbon running at 0 degrees and 90 degrees, often used on bodywork as it is stiff and light but its not very strong. Oh it is definitely not easier to form in to complex shapes regular ud, 2x2t or a 5h material would be much nicer.
Yes, but there are different weaves of 0/90 carbon. I'm no expert, but spread tow carbon seems to have a larger checker pattern than the rest of the 0/90 used throughout the car.
