Williams FW36 Mercedes
neilbah
neilbah
Re: Williams FW36 Mercedes
rscsr
51
neilbah wrote:i thought to be a beam wing then doesnt it need a leading edge where as this seems to merge into the floor/diffuser.. its hard to make out in the pictures because it hasnt attracted as many photos as say the mp29.
http://i.imgur.com/4tdHDiK.jpg
not to scale at all.
I thought that there are no holes allowed in the floor, after the DDD got banned but I haven't checked the rules.
neilbah
neilbah
Diffuser and you can see the beam wing here.
Diffuser with flow-vis
Nose and FW detail
Forza
238
Are they running last years FW for comparison?
Steering wheel is very different for last year.
eyalynf1
eyalynf1
zioture wrote:rear wing is now fixed with a low beam wing ( in yellow), the drive shaft is naked fairing without
http://www.newsf1.it/wp-content/uploads ... -fondo.jpg
Actually it is new, as I was having trouble seeing the leading edge profile of the low wing. Also, the soft focus, or "vignetting" as it is called by design professionals is used to draw attention to the non-soft focus part of the image.
He kept the giant logo off the image, can you all stop picking on him now? It's unseemly.
tomazy
tomazy
208
Sevach wrote:Are they running last years FW for comparison?
It seems so :wtf: don't know what such a comperison would be good for tho.
Nope, that's a 2014 FW and they tested in already in 2013 during the young drivers day with Suzie Stoddart.
muelte
muelte
Don't know exactly what you talk about, but I just see some floor reflections on the sidepod...
Blizz
Blizz
muelte wrote:Don't know exactly what you talk about, but I just see some floor reflections on the sidepod...
Yeah, deleted the post. It's an optical illusion and a good one i dear say. Got me and a few others going for it :lol: Regs wouldn't allow it.
Had this pic posted: http://www.f1fanatic.co.uk/wp-content/u ... 014-12.jpg
It's one of those things, where someone sees one thing and someone else sees the other.
Blackout wrote:Nope, that's a 2014 FW and they tested in already in 2013 during the young drivers day with Suzie Stoddart.
If you look at Forza's first pic, that's a full 1800mm FW.
It's similar (probably the same) to one of the models they raced last season.
dren
226
That looks like a reflection before the undercut.
Honda!
amc
amc
19
Indeed.
2013 Force India (1800mm):
2014 Williams (1800mm):
2014 Ferrari (1650mm):
The Williams is using the one from Austin 2013, presumably to get correlation data and to validate their models of the rear-end aero:
If you can prove that your correlation works for two (quite different) cases of front wing, it is less likely that the accuracy is the result of fudge factors and approximations (and chance) and more likely that the model is accurate for all cases and therefore hopefully for future developments.
"A wise man speaks because he has something to say; a fool speaks because he has to say something."
