https://www.forbes.com/sites/rrapier/20 ... aggerated/
Interesting. If battery decisions are based solely on environmental impact it would seem lead acid is still miles ahead...
This is sensationalistic BS, they´re 99% recyclable but, what´s the rate in the real world. Comparing theory from lead with reality from lithium is as biased as it may be...lead-acid batteries are 99% recyclable, while lithium-ion batteries are recycled at a rate below 5%
Big lead must be behind itAndres125sx wrote: ↑29 Oct 2019, 08:54This is sensationalistic BS, they´re 99% recyclable but, what´s the rate in the real world. Comparing theory from lead with reality from lithium is as biased as it may be...lead-acid batteries are 99% recyclable, while lithium-ion batteries are recycled at a rate below 5%
Of course it matters. They can't promote themselves, with an extremely wasteful and problematic technology that has no practical use.rscsr wrote: ↑23 Oct 2019, 07:02
At first I thought that those cells are a joke, but in those cells Aluminium is converted to Al(OH)3. This is essentially the state of raw Aluminium before the Bayer process but doesn't produce Red Mud. Papers suggest that you need about 70GJ/t to produce pure Aluminium from Al(OH)3 (compared to about 2GJ/t for remelting Al)
This means you need 70MJ/kg = 19kWh/kg to recycle the Aluminium from an Al/Air battery.
This suggests that you have a "recharging" efficiency of probably less than 10% (since such a battery currently stores about 1.3kWh per kg battery). So I don't think that there will be a time where such a battery is viable for daily use, but this doesn't matter for "entertainment" like racing.
Why would you assume that? Re-manufacturing multiple battery packs seems far more troublesome than hauling some generators. If they're even needed. Some tracks might want to provide proper charging ability for the FE cars in the future, if the don't do it already. Laying some cable or connecting some wires is not something complicated.
- It's not about what "they" say, it's about reality. The energy cost of flying cars makes them non-viable electric or not.Andres125sx wrote: ↑23 Oct 2019, 07:45
True. Do you say the same about combustion aircrafts? Because they need several orders of magnitude more energy as ICE are not even a half efficient compared to electric motors
Same as any car or truck, except if it´s a real L5 as I stated there´re no controls into the cockpit so it will be difficult to not play by the rules, much more than any car or truck you see daily on the roads
These are neither actually new nor do they make anything feasible. Even racing series won't adopt primary batteries.Andres125sx wrote: ↑23 Oct 2019, 11:33
The main point IMO is with this new batteries now they're feasible, and that's a huge step forward
Greener than rebuilding a battery at great energy and manufacturing cost.AJI wrote: ↑23 Oct 2019, 10:41Ever heard of recycling? How "green" is shipping a power station to every event?Just_a_fan wrote: ↑23 Oct 2019, 10:29If Formula E is trying to be "green", throwing away batteries after a single use is going against the message, wouldn't you say?
This sort of things happen when they don't bother to build the infrastructure.
Hmmm, with all respect Big T I think you're waaaaaaayyy off the mark there. There are 24 cars, each with a 54kwh battery that is empty at the end of the race, and that's only 1 race! There is no way all of the support services combined use anywhere near that kind of energy.
It is quite a lot if it needs to be fast charged 'at one go' but the garage would have a considerable capacity for all the kit required anyway and there is no need to for a major recharge between qualli and race. I do see what you are saying, but when you consider what power has to be available anyway, would it be more than a couple of supermarket size units extra?AJI wrote: ↑05 Nov 2019, 00:27Hmmm, with all respect Big T I think you're waaaaaaayyy off the mark there. There are 24 cars, each with a 54kwh battery that is empty at the end of the race, and that's only 1 race! There is no way all of the support services combined use anywhere near that kind of energy.
Maybe build a charging station that outside race weekends can be used for passenger car charging...
As said that's ways off. A whole house might only use 200-300 kWh-s of power a month. A single FE car has a 54 kWh battery.
But it does not have to be charged in a single hour
Not without a serious grid connection or bringing a charging station with you...Big Tea wrote: ↑06 Nov 2019, 23:38But it does not have to be charged in a single hour
Ok, I agree the number is considerably higher than I plucked out of the air, but is it doable?
