Alfa Romeo Sauber F1 C37
Re: Alfa Romeo Sauber F1 C37
Nobody would allow any separation on their rear wing on purpose, especially with monkey seat gone. It reduces rear wing performance, diffuser performance as a result and therefore performance of entire car.
Moose wrote:
10 Mar 2018, 04:41
PlatinumZealot wrote:
10 Mar 2018, 01:09
Moose wrote:
09 Mar 2018, 07:05
https://pbs.twimg.com/media/DXyoH7SX0AAPX01.jpg
That's a wing that is... not working well.
Wing's working fine. DRS can cause flow separation at that point.
I don't buy that - mostly because you don't see this on other team's wings, as shown above by the Mercedes flow vis.
Vanja #66 wrote:
10 Mar 2018, 09:35
Different wings.
http://www.espn.com/f1/story/_/id/14012 ... eri-bottas
I wasn't saying it doesn't happen, it most certainly does from time to time. It's a variable geometry with flow barely attached in the first place, of course there's gonna be an unexpected separation. And it's not a big deal since there are no common tools for this issue on the wing on that photo.
My point was you don't want that to happen, ever, as Valtteri demonstrated. :) Even with DRS it's not supposed to happen.
cramr
cramr
Vanja #66 wrote:
09 Mar 2018, 09:54
That separation may be one of the reasons for an unstable performance trough corner.
Do notice there is no Gurney flap on that wing and neither a V slot for vortice generation, so it's not that surprising to see this kind of separation. G-flap and v-slot will help with that, but only the team knows if it will completely prevent separation.
I can be something related to what you say. There is no Gurney Flap so maybe they were investigating the effect of removing the Gurney flap in that wing and see if there was any problem
designf1
designf1
73
ScrewCaptain27
577
First look at the cooling package:
Stacked radiators, a bit like the Caterham CT05.
Via Formulapassion.it
- Serj Tankian
ScrewCaptain27
577
And here’s a diagram by Craig Scarborough:
- Serj Tankian
lucafo
ScrewCaptain27 wrote:
18 Mar 2018, 12:57
https://uploads.tapatalk-cdn.com/201803 ... e78375.jpg
Maybe, is this the same concept Ferrari is using since last year?
ScrewCaptain27
577
18 Mar 2018, 12:57
No, it’s a completely different configuration. Ferrari and Haas radiators are arranged in a forward V pattern, while the Sauber ones are stacked vertically. Closest would be the 2014 Caterham CT05:
Obviously this car is a massive step forward in terms of packaging compared to the Caterham, which had extremely large sidepods.
- Serj Tankian
18 Mar 2018, 16:02
18 Mar 2018, 12:57
https://uploads.tapatalk-cdn.com/201803 ... 93edb2.jpg
No the Caterham has a very classic layout. Many car had/have a similar one. Closest would be the W02
senja
senja
No. It's evolution of C32.
senja wrote:
19 Mar 2018, 04:58
No the C32 was completely different with almost vertical rads
http://img1.auto-motor-und-sport.de/Est ... 659746.jpg
C36 Abu Dhabi vs C37 test spec.
