Alpine A521
Re: Alpine A521
diffuser wrote:
12 Mar 2021, 22:53
PlatinumZealot wrote:
12 Mar 2021, 15:53
Good illustration of how low profile the mclaren rear suspension is. The upper and lower arms are closer together in height.
Over the last Decade, McLaren have been lacking in Mechanical grip. So I'm not sure if you're saying it's good to be different from them or just stating it as neither good or bad, just that it is different?
Can make a good guess that the McLaren engineers see it as some sort of compromise to achieve some aero benefit why the put upper and lower wishbones so close together.
DarkAlman
DarkAlman
Re: Alpine A521
Can't wait to see under the hood to see what's going on with that airbox
Anyone check yet if the sidepods are narrower?
Or maybe they're just adding more cooling for the new engine spec?
Cooling is the likely answer, there's extra strakes in the intake so at least one other radiator has likely been moved into the center line.
Maybe they re-located the entire Turbo inter-cooler up there?
Was Renault running a water-air intercooler last year? I forget
RedNEO
40
Re: Alpine A521
Re: Alpine A521
A new letterbox inlet inside the wall of the lower rollhoop intake.
The RS.18-19-20 didnt have such a thing AFAIk
And they didnt have Alonso in the cockpit.
Re: Alpine A521
DarkAlman wrote:
13 Mar 2021, 07:39
No. An air to air intercooler in each sidepod.
Regarding sidepods:
Sidepod 'hip' look larger on A521 at first glance in this Imola 2020/Sakhir 2021 camparison
https://i.imgur.com/kpiCKn3.jpg
But it's not true
Hip width comparison (pink arrow - angle is not the same but it should make the A521 hip look wider):
https://i.imgur.com/VCPGWn2.jpg
Intake:
Coclusion:
The A521 has more sculpted sidepods at the bottom/more undercut, are bit more sculpted at the top/overcut, and have smaller air intakes
If the purpose of the larger rollhoop is to reduce the sidepods, then the mission is partly accomplished... but that doesn't explain everything and several questions remain:
-why are the air intakes of the roll hoop the same, despite the doubling of its width?
-why did Enstone abandon the RB-style downwashy sidepods (that almost every other team adopted) after one season, and went back to classic and undercut sidepods?
-why is the Alpine coke bottle/waist area fatter? even the RS.17-18-19-20 had a much deeper waist
Re: Alpine A521
They are running the shorter roll hoop cover today + the smaller hot air exits at the back of the car
Re: Alpine A521
Via Scarbs
fouad1979
fouad1979
Re: Alpine A521
Blackout wrote:
13 Mar 2021, 10:27
https://i.imgur.com/6oLkfVF.jpg
Great u cant notice that when his running
fouad1979
fouad1979
Re: Alpine A521
Blackout wrote:
13 Mar 2021, 10:27
They are tweaking the floor also , it was little bit basic and simple comparing with the others
Re: Alpine A521
GoranF1
GoranF1
151
Re: Alpine A521
Reports from track saying car looks very s table. Karun Chandok
Nano4k
Re: Alpine A521
could they run different engines?
aerofoilf1
aerofoilf1
247
Re: Alpine A521
Floor edge options...
Re: Alpine A521
Re: Alpine A521
Looks like they're adjusting the amount of cooling they need. Came in big and wide for starters, now reeling it in.
Maybe the the bulb behind the roll hoop might shrink down for the first race too.... Evaluating whatever they changed there?
