According to what you wrote biplanes could never fly. Pressure on top of the little wing is higher than pressure between it and the nose and below the nose you have again lower pressure than one on top of the nose. So, I say downforce.joseff wrote:- suck the little wing down
- suck the nosecone up
You have to remember that you can't consider any single element of the car on it's own. All parts of the system interact with all the other parts. Setting aside the fact you've drawn a lifting surface in your diagram, not a downforce-generating one, your arrangement would cause an increase in drag and a loss in overall front downforce as it would disrupt the airflow over the rear part of the nose behind your duct. I have to say, you have some odd preconceptions about how current aero works - the whole point of the raised nose arrangement is that the nose as a whole generates downforce, not lift.manchild wrote:Small wing shaped part on top would generate downforce since between it and the rest of the nose Venturi shape would cause low pressure zone. Existence of that small wing on top just above the zone of low pressure generates downforce and prevents low pressure from lifting nose upwards. When I was thinking about this idea I had in mind reduction of upforce generated by conventionally curved nose. Another benefit would be lowered COG and perhaps more downforce generated in corners relative to conventional noses.
If the nose is working correctly, air is traveling faster under the nose than above it, over (more or less) the whole length of the nose. This generates downforce. With your slot, as the air seperates from the rear of the aerofoil and tunnel it becomes turbulent, disrupting the flow over the rear of the nose and reducing the downforce generated at the rear of the nose. So you're trading the tiny area of the wing surface off against the much larger area of the nose. Net loss of downforce.manchild wrote:Could you backup your claims and explain why current nose creates more downforce than the one I suggested?
It's a construction issue. Your suggestion reduces the consistent cross-section of the nose, requiring it to be of heavier construction to maintain stiffness and remain a viable crash structure. The guide structures on the side/top of the nose will have to be solidly constructed to support the wing, adding further weight. It's not quite up to your standard, but I've done a little diagram:manchild wrote:I also don't understand how you can say that my suggestion would bring COG higher when what I basically suggested was to lower the thick and heavy top of the nose down, with adding only small hollow wing which would remain on height of current nose.
Well, whatever you use - I think the professionalism of the art is half the reason why your concept has had such widespread dissemination.manchild wrote:I guess me not having idea how aero works is best proved by me guessing the shape of R28 nose and original nose idea that's now all over the web.
Thanks for the photoshop compliments although I've never used it in my life.
Unfortunately, '2D' CFD isn't going to give anything like accurate results, because as you rightly point out, the the world is in 3Dslimjim8201 wrote:Manchild, as with most 2D simulations, unless the system in question is truly 2D (an airplane wing...and even that is a stretch since back sweeping/end effects/fuselage effects are not taken into account), 2D simulations are best for conceptualization/prelim testing. For this design to be tested properly, the whole front nose cone + wings must be simulated. But from my nose cone-only 2D tests, I did see a consistent reduction in life (more downforce) and an increase in drag. It may not be worth much in the long run, but it is what it is...
The full 3D testing will tell a much better tale. Good find on the Google Sketch-Up models. I'll see if I can use them this week. I already have a nice (if simplified) F1 car model that I've been messing around with for a while.
The nosecone is the primary frontal impact absorbing structure. It has to be, because right behind the bulkhead where the nose attaches to the tub is the driver's feet! Trust me, there are no 'minor' impacts in F1. What looks like a little scrape on TV is a crash that would likely kill you if you were in a Ford Fiesta. The front wing on an F1 car is freakishly strong. If the car was suspended from a crane, two adults could hang from EACH END of the wing without it breaking. Snapping one off requires major forces.slimjim8201 wrote:Someone please correct me if I'm wrong, but is the nose cone really a structural piece involved in crash energy absorbtion? From what I can tell, the whole nose cone seems to be a simple exoskeleton designed to withstand little more than aerodynamic forces at track speeds. Seems like front wings and aero bits are constantly being sheared off the car in minor collisions. Perhaps the nose cone body itself has some form of internal crash absobrtion qualities?
Absolutely right.slimjim8201 wrote:Again, the only thing I can say with certainty at this point is that the addition of an in-nose-cone wing will increase the overall drag. Design changes at the very front of the car, however small, have a more extreme effect than at any other area.
I don't even know where to start. Please explain to me the physical principles where lowering the nose and making it of smaller cross section allows you to thin the structure.manchild wrote:shawness, it could perfectly fulfill safety and structural stiffness demands if made like lower drawing shows. Not just the COG but the overall weight of nose could be reduced too since vertical sides that extend above the ceiling of the nose could be made much thinner or even hollow. Lower construction with all 4 sides closed is even stronger than similar construction with same wall thickness. Therefore, the boxy part of the nose could be made with thinner walls which would bring even greater reduction of weight while maintaining identical impact absorption capabilities. The bigger the box the thicker the walls and opposite.
I thought it is more than logical. A rectangle or a pipe shaped object, whatever, which has diameter of 5 inch is much stronger than one with diameter of 50 inches if they are made of identical thickness material. So, if thickness of current Ferrari nose is for example 1 inch and if the cross section is reduced that would allow thinner walls (less weight). As simple as that.shawness wrote:I don't even know where to start. Please explain to me the physical principles where lowering the nose and making it of smaller cross section allows you to thin the structure.
