xpensive wrote:"Validate your tools" is a very interesting expression kilcoo, care to elaborate on that, possibly through an example?
Basically, you try to evaluate the physics of your problem, in this case heat transfer and jet plume flow. If you can find experimental data (or make experimental data) that does both, even better.
As I indicated, there are countless experiments of heat transfer from jets, be they impinging or surface flow.
Such things are important in the field of power generation for instance, another area would be aircraft heat exchangers (remember the 777 that came down at heathrow - the problem was tracked to bad heat exchanger design).
So, you compare your predictive tool to the results of such experiments by trying to replicate it.
The other area is the prediction of the jet (exhaust) flow itself, again, no shortage of test cases. An example of one I've used in the past is NASA TN-D-3601.
Chances are Red Bull did their own in-house tests based on last years car, and then compared that to simulations. From there you can quickly get a feel for how qualitative and quantitatively accurate your simulation tools are.
