Difficult to work out unless there are more details but unlikely.
Of course Charlie Whiting would be more likely to give a definite answer.
IMO the regulations are not specific enough in this area.
Thanks for clearing that up ringo.ringo wrote:A fuel tank is part of the sprung mass and it would be supported by the suspension. nothing active about that.Blaze1 wrote:Hello
I've been wondering, rather than allowing the fuel cell to be placed on a dynamic mount, couldn't a baffle within the fuel be used to adjust the ride height in a similar fashion. Rather than worrying about the cg shift of a large amount of fuel, in this case you'll only be concerned with the baffle?
A baffle would be a breach of the fuel cell construction regs. It would be a safety issue if suspension control has to pass through the cell wall.
I was thinking along the same lines.roost89 wrote:I was wondering. It may be a bit daft but could RBs advantage of ride-height be an advantage of having their pull-rod as opposed to Push-rod?
Admittedly not that with it in terms of the pros and cons of each. But is it possible?
The headline of that page is perhaps a little misleading (perhaps GPUdate employ some ex currant-bun hacks??).ernos5 wrote:Confirmed via FIA, Ride Height Control Systems are Illegal
http://f1.gpupdate.net/en/formula-1-new ... e-illegal/
This is quite specific to "while the car is under Parc Fermé conditions", it says nothing about "while the car is RACING" nor does it mention "while the car is completing it's in lap at the end of Q3" (although I'm not sure if this forms part of parc fermé or not. Advice anyone??).gpupdate.net wrote:Any system device or procedure, the purpose and/or effect of which is to change the setup of the suspension while the car is under Parc Fermé conditions, will be deemed to contravene article 34.5 of the sporting regulations," reads the FIA message received by Autosport.
The rules state a minimum ride height at all times, enforced by the plank. So if you had a conventional set up that lifts the car, then it would fail scrutineering when stationary for a while or if the system failed. Also a component failure would drop the car to the floor in the race. By reversing convention, the car is always going to comply with the ride height rule, and any failure would allow the car to keep on racing (alebit rather high).bill shoe wrote:[It's interesting that the Red Bull system appears to pull the car down to a dynamic ride height unlike most production Nivomat systems that push the car up to a dynamic ride height. This Red Bull reverse direction may have something to do with getting to dynamic ride height most efficiently on the warm up lap. Or maybe it's just a practical matter where you can't push the damn car around the pits if it has lowered onto the plank...
That's a misleading headline, it only refers to Parc Ferme.ernos5 wrote:The headline of that page is perhaps a little misleading (perhaps GPUdate employ some ex currant-bun hacks??).gpupdate.net wrote:Confirmed via FIA, Ride Height Control Systems are Illegal
[quote"F1 Tech Regs"]3.15 Aerodynamic influence :BBC wrote:The letter added that the FIA believed "any self levelling damper system is likely to contravene (article) 3.15 of the technical regulations".
