McLaren MP4-29 Mercedes
CjC
CjC
Re: McLaren MP4-29 Mercedes
I think they'll struggle to get any where near the works team just with an update to the side pods, saying that Marc said that mclaren was wasting space the size of a small suitcase, in f1 that is huge!
You have to wonder why it's taken mclaren so long to redesign the side pods just for smaller exhausts or are they planning more? Maybe accommodating the new exhausts is a bigger job than I imagine.
Just a fan's point of view
akshat21
akshat21
CjC wrote:I think they'll struggle to get any where near the works team just with an update to the side pods, saying that Marc said that mclaren was wasting space the size of a small suitcase, in f1 that is huge!
I am sure its just not about making the sidepods slimmer. They must have tested all aspects and dimension of the PU and ancillary systems for packaging and would have worked every surface of the side pods for maximum efficiency and balance with the specification they had. Remember the car was being built since late last year. So they must have done a lot of testing with aero surfaces based on data given by Mercedes. Now if there is a space big enough to fill a suitcase, the aerodynamics would have to be re-worked to extract the most benefit of the tighter packaging along with making sure that they optimize (and not compromise) the current aerodynamics of the car.
Also, the slimmer packaging might lead new wing/nose design (as seen in Bahrain test) as they would need to change the way that air is channeled to the rear of the car VIA the new sidepods.
All this can take a lot of testing and time.
avatar
avatar
I'd guess a big part of the delay is redesign of the shape (or at the very least repackaging) of the radiators and other sodepod contents.
If the just "slimmed down" the sidepods by moving the skin into the existing empty space,it would be a pretty abrupt change in radius of the sidepod curve and may not be helpful.
I'm guessing small step for China = redesigned sidepod skin to take advantage of a bit of the free space, still leaving some until...
...a bigger update for the return to Europe with revised radiator/sidepod innards, optimised for the available space created by the log manifold.
China 2014 via AMuS
And peeling of the Gulf Air Stickers....
gray41
Underside of the engine cover.
Lewis Hamilton #44
2016
Poles: *****
Wins: ***
lukje
lukje
Well, looking at the "Gulf Air" logo being peeled off, it looks like the same sidepods are going to be used. That is unless they bring something new yet, which I consider unlikely.
JimClarkFan
JimClarkFan
27
Still have the butterflyl..... :?
Maybe it is worth it afterall
basti313
basti313
JimClarkFan wrote:Still have the butterflyl..... :?
Yes, but they are preparing one car with the double butterfly and one with only one butterfly for FP. So we will see what works best on saturday.
Don`t russel the hamster!
Owen.C93
Owen.C93
177
The bottom one just wasn't fitted yet.
mclaren_mircea
mclaren_mircea
Correct me if I'm wrong, but from what we can see the size of the sidepods appears to be the same. Whith all the respect, what we saw on F1elvis it's not realistical for China :(
mclaren_mircea wrote:Correct me if I'm wrong, but from what we can see the size of the sidepods appears to be the same. Whith all the respect, what we saw on F1elvis it's not realistical for China :(
We only saw one Sidepod yet, and that was directly from Bahrain. It's a little too early to say they don't have other ones to Test.
mclaren_mircea
mclaren_mircea
I hope you are right, but that sidepod came from U.K not from Bahrain. Normally they can test two FW, two RW, two noses, but I can't believe they can run different bodywork with slimmer sidepods and than the bigger one that we saw until now. I hope I'm wrong and that you are right Thunders :)
Well i said it came directly from Bahrain because there was the Gulf Air Sticker on it.
I'm definetly not sure if Macca will bring new Side Pods (if you ask me Barcelona would be the safer Bet) but we should wait till after FP2 to judge that. ^^
otbsti
Still surprised they haven't covered the driveshafts with an aerodynamic cover like most everyone else... they had them covered last year.
"Winning is the most important. Everything is consequence of that."
-Ayrton Senna
Mercedes AMG Petronas
Lewis Hamilton #44
Del Boy
Del Boy
otbsti wrote:Still surprised they haven't covered the driveshafts with an aerodynamic cover like most everyone else... they had them covered last year.
The rules prevent drive shaft fairings, exclusively used as a fairing.
Last year the rear part of the wishbone incorporated the drive shaft. Therefore because this year the rear most wishbone is so far back to facilitate the butterflies it can't incorporate the drive shaft.
Or Perhaps the Magnus effect is helping with the butterfly bits!!
